Has anyone done this? I'm sure it would work fine on manual, but if it was all on the same channel, how would it handle power tracking and such? Or would it just not work so well?
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | May 15, 2012 19:13 | #1 Has anyone done this? I'm sure it would work fine on manual, but if it was all on the same channel, how would it handle power tracking and such? Or would it just not work so well?
SMP_Homer Cream of the Crop More info | May 15, 2012 19:50 | #2 I use a pair or TT1 at every wedding - all triggering the same remote flashes EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
K.C. Senior Member 319 posts Joined Jun 2010 More info | May 16, 2012 01:38 | #3 It's a common practice and works just fine.
May 16, 2012 09:16 | #4 SMP_Homer wrote in post #14437387 I use a pair or TT1 at every wedding - all triggering the same remote flashes Thanks. I'm just wondering if I wasn't using manual and changed settings on the cameras if the power tracking would still work right. Or if I could use a pair of AC3's and have slightly different settings on each...I guess the best way to find out is get another set.
SMP_Homer Cream of the Crop More info | May 16, 2012 09:24 | #5 Numenorean wrote in post #14439899 Thanks. I'm just wondering if I wasn't using manual and changed settings on the cameras if the power tracking would still work right. Or if I could use a pair of AC3's and have slightly different settings on each...I guess the best way to find out is get another set. each TT1 isn't aware of the other so that's not an issue EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
May 16, 2012 09:32 | #6 SMP_Homer wrote in post #14439956 each TT1 isn't aware of the other so that's not an issue it's the camera/TT1 that's sending the info to the remotes before each fire so regardless of what TT1 #1 does, when TT1 #2 sends a command, no previous info at the remotes exists Nice. Thanks for the info!
| Latest registered member is semonsters 1082 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
