Thread started 17 May 2012 (Thursday) 11:47
600EX-RT for fill with sunlit background
dmward
Gallery: 29 photos
May 17, 2012 11:47 |  #1
I wanted to do some additional testing with my 600EX-RTs to find out just how well they will work for fill flash with the subject in shadow and the background sunlit. More or less a normal wedding day situation. :-)
I also wanted to see what the impact of F stop would have on the background; a line of trees about 40 ft behind the subject. And I got the additional benefit of seeing how good the off center zone focus capabilities of the 5D3 will be capturing focus since I was the only subject available. (So bear with the self portrait examples. :-) )
5D3 with 85mm F1.2L II on a tripod about 8 ft from subject. I set the AF to lowest right using the zone capability. That showed there were 4 AF segments active.
The camera was set to Av, ISO 50, -1 EV exposure compensation, metering is evaluative.
Flash was on a stand about 4 ft from subject camera left and looking down about 45* through a Westcott 32" collapsible umbrella. Flash was ETTL with HSS activated and no flash exposure compensation.
The focus at F1.4 isn't precise because of the hit or miss nature of a self portrait.
This is the result at F1.4, 1/3200;
This is at F4.0, 1/800;
and this is F8.0, 1/100; Here the forehead reading was about 1/2 stop hot. Pulling exposure down -.5 brought the forehead reading to within 2 %. All the shots with shutter speeds above sync speed had readings within about 2% of each other.
This was accomplished with the 600EX-RT, realistically the same results would occur with a 580EX or 580EXII, or a Nissin Di866 etc.
aztecdaz
May 17, 2012 12:04 |  #2
Looking good. Im planning on doing something similar myself over the weekend utilising the st-e3 but so far it looks as if this is a winning set up, my pocket wizard flextt5s were sometimes a bit unpredictable especially when in HSS
5DIII Gripped | 5DII+wft-e4II | Gripped 7D | 24-70L | 70-200 2.8L IS | 85LII |17-40 L | 600ex-rt x3 | st-e3-rt |Quadra A Heads | BRX500 x 4 | lots of Rotalux Goodies
kouasupra
May 17, 2012 12:43 as a reply to  @ aztecdaz's post |  #3
Great testing David. From your testing do you think it's worth upgrading to the 600EX-RT?
dmward
Gallery: 29 photos
May 17, 2012 12:55 |  #4
kouasupra wrote in post #14446255 (external link)
That's an interesting question.
I used PocketWizard ControlTL stuff with Nissin Di866 flashes for a couple of years and they work well.
I got the 600EX-RTs primarily because I was also planning to get a 5DIII.
There are definitely some nice features, and especially using the two together.
They really don't deliver more or better light than 580EXs or Di866s.
For me it was kind of a combination gear head and wanting to have the absolute minimum amount of equipment when I'm shooting alone.
Its really going to be a personal decision for everyone.
Mikey1
Joined Jan 2012
May 17, 2012 12:57 |  #5
straight on or through an umbrella?
Canon 50D--40D--70-200 F2.8L--50MM 1.8--85 1.8 USM--18-55IS--430EXII x 2--RF602s--AMBITION
chris_holtmeier
Joined Sep 2011
May 17, 2012 13:08 |  #6
Mikey1 wrote in post #14446309 (external link)
OP said through 32" Westcott umbrella
https://www.facebook.c​om/FotonFoto (external link)
dmward
Gallery: 29 photos
May 17, 2012 14:56 |  #7
chris_holtmeier wrote in post #14446357 (external link)
For sure. I have some test shots straight, the shadows are very sharp. Using the flash without softening the transitions would make for a much less pleasing result.
Here's the on-camera direct shot for reference. F1.2, 1/4000. It was about half a stop hot on the forehead as well.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/05/3/LQ_596439.jpg
Image hosted by forum (596439) © dmward [SHARE LINK]
dmward
Gallery: 29 photos
May 17, 2012 15:15 |  #8
Thought I might as well complete the explanation by showing a shot without flash.
This was pulled up 2/5 stops in lightroom to get the forehead to read the same as it does in the flash images. F1.2, ISO 50, 1/4000.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/05/3/LQ_596443.jpg
Image hosted by forum (596443) © dmward [SHARE LINK]
kouasupra
May 17, 2012 15:51 |  #9
dmward wrote in post #14446302 (external link)
I also have the pw mini/flex system with my 580ex ii. It works fine with my 5D3, but the 600ex compliments the 5D3 really well. I love the new features on the 600 and especially the larger lcd, but with the same power output. I don't know if it's worth the extra money.
Too much toys to buy, and yet so little money..LOL.
c2thew
May 20, 2012 23:37 |  #10
fantastic test
Flickr (external link) |Gear|The-Digital-Picture (external link)|The $6 mic | MAGIC LANTERN (external link) | Welding Filter
Go Support Magic Lantern 2.3!!
kobeson
Joined Jun 2010
May 23, 2012 01:13 |  #11
Hi dmward, just wondering what advantages a 600EX-RT has with the 5D mkiii?
I am in the market for a 5D3, and also a new flash.
1Dx | 5D III | 1D IV | 8-15 | 16-35L II | 24-70L II | 70-200L II | 400L II | 1.4x III | Σ85 | 100L | 3 x 600EX-RT | ST-E3-RT
website  (external link)facebook (external link)
chris_holtmeier
Joined Sep 2011
May 23, 2012 06:22 |  #12
kobeson wrote in post #14472143 (external link)
Built-in radio triggering.
kobeson
Joined Jun 2010
May 23, 2012 19:27 |  #13
chris_holtmeier wrote in post #14472639 (external link)
But wouldn't a radio transmitter still be required? Or does the 5D3 not require one?!? Apologies for my amateurish questions :o
oldvultureface
Gallery: 85 photos
May 23, 2012 19:57 |  #14
kobeson wrote in post #14475760 (external link)
In its own menu system, the 5D3 (and eventually the 1DX) supports the radio capabilities of the 600 and ST-E3.
timnosenzo
May 23, 2012 21:34 |  #15
The radio function will work on the 600EX-RT's with any Canon DSLR, but there are some functions that will only work with the 5D3 or newer cameras. I can't recall what it is off the top of my head, but the 600EX manual spells it out.
8,676 views & 0 likes for this thread, 13 members have posted to it.
1625 guests, 141 members online
