Thread started 17 May 2012 (Thursday) 16:33
Hypersync mode w/Elinchrom RX
RichNY
May 17, 2012 16:33 |  #1
Has anyone had succeess using Pocket Wizards and Hypersync mode with a Ranger RX or 600RX?
I've tried using a Flex TT5 on camera with an ST4 on the Ranger Pack and with a Multimax on the pack going into the sync port.
Programmed the on-camera TT5 to not use HSS and to use hyper sync above sync speed, tried using fast, medium, and short duration on the transmitter, used -1600, swapped out the transmitter for another one, etc.
Wondering what step I'm missing or doing wrong.
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
K.C.
Joined Jun 2010
May 17, 2012 17:00 |  #2
Do you have the FlexTT5 and the ST4 set to work on the same controlTL channel ?
Hypersync with the Multimax receiving would have to be done with manual hypersync setup and a standard channel.
Aressem
Gallery: 39 photos
May 17, 2012 17:38 |  #3
K.C. wrote in post #14447396 (external link)
Which head r u using? A or S?
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
ZXDrew
May 18, 2012 09:50 |  #4
A clean 1/500th is the fastest you can get with that setup.
You need a tt5 on the strobe PLUS a tt5 or tt1 on camera to do hypersync.
I use a tt1 on camera and PW plus II's for my strobes to get 1/500th clearn and up to 1/1250th usable.
PhotoWolfe.com (external link)
Facebook.com/PhotoWolfe (external link)
Gear / My flickr (external link)
K.C.
Joined Jun 2010
May 18, 2012 20:23 |  #5
ZXDrew wrote in post #14450395 (external link)
Those are exactly the results I get with a 5DII.
However the OP is using a D3 which should have much better success at higher shutter speeds.
ZXDrew
May 18, 2012 20:41 |  #6
The crop sensors actually have the best chance at getting higher shutter speeds. Unless he's using the mini/flex or flex/flex combo, he won't get any better than above. I can get up to 1/8000th with my mini/flex combo.
bobbyz
May 18, 2012 23:08 |  #7
ZXDrew wrote in post #14452995 (external link)
Mind showing some shots.
Fuji XT-1, 18-55mm
umphotography
grabbing their Johnson
Gallery: 21 photos
May 18, 2012 23:31 as a reply to  @ bobbyz's post |  #8
F/2.8 @ 1/1600 100 iso with an ab1600 just above 1/2 power 10Ft from subject.......I can go to 2500 all day long with a flex on the strobe and a mini in the camera.......No problem
IMAGE: http://i195.photobucket.com/albums/z19/karenbaby12/IMG_4041-1.jpg
F/2.8 @ 1/2500 100 ISO ambient was F/13---Power was at 3/4 on an AB1600- wanna see more ?? I will be using this set up for all my outdoor photo needs. It works great
IMAGE: http://i195.photobucket.com/albums/z19/karenbaby12/IMG_4033-1.jpg
Mike
www.umphotography.com (external link)
Facebook (external link)
jdotuk
May 19, 2012 11:34 |  #9
All you should need is the mini/flex on camera and the st4 plugged into the ranger to access the control TL features. Unless it's a ranger quadra - st4 is regretibly uncompatible.
Jeremiah (J.) Mullins
5D & 7D | 35L, 50 1.4, 85 1.8, 135L | X100s
2,973 views & 0 likes for this thread, 7 members have posted to it.
1338 guests, 136 members online
