Thread started 19 May 2012 (Saturday) 03:16
Why do some people use 1/30 or 1/60 ss instead of 1/50 or 1/125?
thedcmule2
Joined Nov 2011
May 19, 2012 03:16 |  #1
The way I learned it, if you shoot at 24fps, your shutter speed which is -not- equivalent to your frame rate should be double your frame rate or whatevers closest. So I shoot 24p at 1/50 and 60p at 1/125. I saw a pretty successful video director use 1/30 for 24p and 1/60 for 60p. He gets a stop more light than me and it makes me want to do the same.
So...what do you think?
John ­ Sims
May 19, 2012 03:35 |  #2
Try it and see. It's your video, if you like it what's the odds?
My thoughts are that the images will appear softer as you are taking longer to expose each individual frame and thus the subject will have more time to blur within the image. Great if you are trying to convey a dreamy or speedy image or to generate greater contrast between a static subject and other things moving around it - the moving things will be blurred and the static thing crisp.
John Sims
Canon 60D, 30D, 10D, AE1 & some other stuff
mizer357
May 19, 2012 13:52 |  #3
it's true, you get some extra light taking the shutter down from 1/50 to 1/30, but you will also get more motion blur on moving objects, which becomes more pronounced as you slow the shutter down further. 1/30 isn't a bad tradeoff for more light sometimes, especially for run-and-gun event work in dark corners, but if you're looking for natural motion blur, a shutter speed double the framerate is the accepted standard. as you probably have already figured out, shooting at faster shutter speeds will reduce motion blur, for a hyper-real look, which is used to effect all the time.
IUnknown
May 22, 2012 15:38 |  #4
Double the shutter speed was a convention used in the day's of a mechanical shutter. In the digital age, it doesn't matter as much. The increase in motion blur is negligible. The other time it helps out is when you get flickr from LED or florescent lighting.
Fiske | Film (external link)
5D Mark II | Canon 70-200mm f/2.8L IS USM | Canon 35L | Sigma 85 1.4 | Helios 44M-6 58mm(M42) | Zeiss 50mm 1.4 (C/Y) | LEICA 50MM SUMMICRON-R F2 | Canon 135L | Elmoscope anamorphic lens | 430EX II
thedcmule2
Joined Nov 2011
May 22, 2012 22:49 |  #5
Well in that case why cant we go even lower than 30?
RockSlut
Joined Nov 2003
May 23, 2012 04:40 |  #6
thedcmule2 wrote in post #14471666 (external link)
Because your shutter speed needs to be fast enough for the camera to generate the number of frames per second that you're shooting at.
Angus
www.angusyoung.com.au (external link)
Movie Stills Photography www.production-stills.co.uk (external link)
thedcmule2
Joined Nov 2011
May 23, 2012 14:08 |  #7
Very smart :p thanks guys
2,520 views & 0 likes for this thread, 5 members have posted to it.
1346 guests, 176 members online
