I have this lens on my T2I, right now, but in using it, I feel I need a bit more reach, but with similar Wide angle, if that is possible.
Thoughts?
displacedtexan Member 174 posts Joined Feb 2008 Location: Louseyana More info | May 20, 2012 04:23 | #1 I have this lens on my T2I, right now, but in using it, I feel I need a bit more reach, but with similar Wide angle, if that is possible.
kin2son Goldmember 4,546 posts Likes: 3 Joined May 2011 Location: Sydney, Australia More info | May 20, 2012 04:35 | #2 Permanent banCannon 18-200, Tamron 18-270 PZD. 5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
CHASLX200 Member 138 posts Joined May 2012 Location: Tampa FL area More info | May 20, 2012 06:58 | #3 Silverspeed.
Cokeman Member 168 posts Joined Aug 2010 More info | May 20, 2012 10:39 | #4 28-300L? T2i, 70-200/4, 28/1.8, 85/1.8, 28-135, 18-55, 55-250, 430EXII
My first good lens was the 28-135 and I felt it wasn't wide enough for my needs where 135 was plenty. For you however your only options are what has been mentioned. Canon 18-200 would be a best bet. A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
mrmarie Member 57 posts Likes: 1 Joined Feb 2012 More info | May 20, 2012 17:33 | #6 24-105 best walk around lens
wayne.robbins Goldmember 2,062 posts Joined Nov 2010 More info | May 20, 2012 17:41 | #7 I would guess that you didn't read the post- eh ? EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
saintz Senior Member 428 posts Joined Mar 2012 More info | May 20, 2012 18:22 | #8 Get a 55-250 and swap lenses, or get the 18-200 for an all in one. Sony A6000 | 18-55 | 16-50 | 50 f1.8
MrBPix Senior Member 492 posts Likes: 4 Joined Nov 2007 More info | May 20, 2012 21:23 | #9 It sounds like you are looking for a single-can-do-everything lens. If this is true, the Canon 18-200 is pretty much your best bet. But while the 18-200 has the focal range you are looking for in a single lens, it has drawbacks. One of the best features of the SLR camera is interchangable lenses.
mes2424 Junior Member 27 posts Joined May 2010 More info | May 21, 2012 06:13 | #10 What about on the 5D3? Something longer than the 24-105? Have my L's.....16-35II, 24-70 L, 70-200 II but I want a decent lens for walking but something with more range than the 24-105. 5D MK III gripped /24-70 L/70-200 MKII L/ 16-35 MKII L/Canon 85 1.8/Canon 600EX-RT (4) /RRS BH55/Gitzo GT3541LS/2x III TC/ ST-E3-RT
ScottM Goldmember More info | May 21, 2012 06:52 | #11 mes2424 wrote in post #14462299 What about on the 5D3? Something longer than the 24-105? Have my L's.....16-35II, 24-70 L, 70-200 II but I want a decent lens for walking but something with more range than the 24-105. Not many options here. Either the Canon 28-300mmL (which is quite expensive and heavy), or the Tamron version. The 28-135mm will give you a little more reach than the 24-105L, but the difference between 105mm and 135mm isn't much.
| Latest registered member is MWCarlsson 1272 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
