Thread started 20 May 2012 (Sunday) 11:55
Any ideas on a small (or very weak) flash?
AirbusA380
May 20, 2012 11:55 |  #1
My photography focuses on meals served onboard international business/first class travel. One of the challenges is to get lighting right; especially when I travel red-eyes, I often choose to have my meal mid-flight when lights are dimmed and am stuck with just a reading light. I thought about using a flash at 1/128th power, possibly with a diffuser.. What are your takes on this? Does anyone have any other ideas? Perhaps a very small flash I am unaware of (I was thinking, they have pocket-sized beamers nowadays.. are there any similar pocket-sized mini flashes? Unaware what to Google to find out..)? Any input is appreciated!!
-Dan
Canon 300D | Canon 400D | Canon 50D
Canon 17-55mm f/2.8 IS | 70-200mm F4L | 50/1.8 | 50/1.4 | 85/1.8
kokakaste2
May 20, 2012 12:47 |  #2
Maybe a LED panel instead of flash?
Oskar (Oscar) - stuff I use- Flickr (external link) - My Facebook page (external link) :)
Stuperfox
Gallery: 12 photos
May 20, 2012 12:57 |  #3
So just to make sure, you are taking images of meals served on flights while in flight?
If so, then I would say go with a light panel(http://www.bhphotovide​o.com …_38_Flat_Panel_​Flash.html (external link)). I am not a fan of LED lights, they dont give good smooth light and are really dappled unless you spend a lot of money to get a good system.
The panel flash will be much softer, easier to stop the motion and will be simpler to use in the end.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
Curtis ­ N
Master Flasher
May 20, 2012 13:05 |  #4
I would think you can bounce the flash off the ceiling - or whatever is above the seat. It's usually light grey so color shouldn't be an issue.
A Canon Speedlite 270EX II should get the job done (not the original 270EX).
Also there are diffusers like this (external link) that will diffuse the light from your camera's built-in flash.
So, your job is to get on a plane, sit in first class and take a picture of the food? Nice gig! Are they hiring?
denncald
May 20, 2012 15:36 as a reply to  @ Curtis N's post |  #5
Take a look at this macro LED light.
http://www.amazon.com …anon-Tamron/dp/B003LYF5P2 (external link)
Dennis
AirbusA380
May 21, 2012 00:52 |  #6
Thanks, folks! The thing I'm worried about is it has to be a weak flash/lighting source. I don't want to disturb other passengers on-board. This is what makes it so different from regular food photography, or any sort of photography for that matter. The GN for the Sun Pak Flat Panel Flash for example is 38, which seems total overkill. Moreover, for this very same reason I don't like to bounce the flash off the ceiling.
-Dan
Curtis ­ N
Master Flasher
May 21, 2012 05:33 |  #7
Any of the Canon Speedlites have the ability to fire at well under 1% of their capacity in E-TTL mode.
But in a dark environment, even a weak flash is going to get noticed.
Foodguy
Joined Mar 2012
May 21, 2012 07:47 as a reply to  @ Curtis N's post |  #8
Vellum/tracing paper/writing paper/diffusion material/shower curtain etc, taped over your flash will cut the light to any degree you want or need.
My answer for most photography questions: "it depends...'
kokakaste2
May 21, 2012 12:07 |  #9
Foodguy wrote in post #14462537 (external link)
or just use ND gels? :)
sportmode
Joined Nov 2010
May 21, 2012 13:59 as a reply to  @ kokakaste2's post |  #10
How about using an iPad for your softbox?
http://itunes.apple.co​m …for-ipad/id415056105?mt=8 (external link)
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
2,063 views & 0 likes for this thread, 7 members have posted to it.
666 guests, 119 members online
