Thread started 20 May 2012 (Sunday) 13:42
Eclipse
L.Morey
May 20, 2012 13:42 |  #1
Can you safely take a pic of the eclipse today without screwing up your camera with a polirizer on it
7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
Sigma 150-500 , Sigma 18-200f4-6.3 , Canon Ste2 , Canon
580mki , Canon 580mkllx2
http://lwmorey.zenfoli​o.com/ (external link)
Wilt
May 20, 2012 13:59 |  #2
Polarizer reduces visible light, but does not reduce IR and UV light rays sufficiently. As a result, viewing thru the viewfinder is dangerous to your eyes. And the current wisdom, until proven otherwise, is to NOT aim the camera at the sun because of heat damage to the closed shutter, and to NOT aim the camera at the sun while in Live View mode due to heat damage to the sensor -- unless you have the proper solar filter in front of the lens.
This guy managed to get a shot with a 200mm lens on his 5DIII using a variable density filter (see reply #1)
http://www.canonrumors​.com/forum/index.php?t​opic=6643.0 (external link)
He apparently did not look thru the viewfinder to aim, did not use Live View either, but aimed and shot trial shots by trial and error until the sun was suitably framed, and (one guesses) managed to do so without causing the metal shutter blades to be damaged :eek:
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
May 20, 2012 14:24 |  #3
been there done that using a welders sheild. Can't say the results were any better than seeing it covered on television, kind of like going to the grandcanyon and seeing better work at the gift shop on the calenders, why bother? It was an interesting experiment but I fealt I had risked what was then a very expensive camera for a less than thrilling result.
Gonna be overcast and rainy here today anyway, I would be more concerned about water damage, or my own sanity if I went out and set up for something I am not going to see anyway :)
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
876 views & 0 likes for this thread, 3 members have posted to it.
Eclipse
1024 guests, 106 members online
