Thread started 20 May 2012 (Sunday) 18:56
EF 70-200mm 1:4 L auto focusings problem
Maxum
May 20, 2012 18:56 |  #1
Hi,
I had this lens, 70-200mm 1:4 L, for about 2+ years and I purchased it used. It has never been dropped or even bumped hard, by me,...other than putting it in the case. I always use the hood and filter but recently it responds poorly in auto focus.
In auto focus it is constantly hunting, even in good lighting conditions.
I am about to send it off to be repaired but I wanted to know if there was an easy fix (i.e. some form of cleaning that may fix this).
Kevin
Canon XTi, Canon 70D (70-200 f/4 L) + (EFS 18-55)+(EFS 18-55 f/3.5-5.6 IS STM)+(EFS-55-250 f/4-5.6 IS STM)
red ­ snapper
Gallery: 104 photos
May 21, 2012 02:11 |  #2
What focusing settings are you using, AI servo might cause it to constantly hunt as it is always re-adjusting focus.
If you do what you always do, you get what you always get.
7D, 400D, Sigma 30 f1.4, Sigma 17-70 f2.8-4.5, Canon 70-200 f4L (non IS), Canon 10-18mm f4.5-5.6 STM, Petri 50mm f1.7, Revuenon-Special 35mm f2.8, Revuenon-Special 135mm f2.8, 430 EX II,
flickr (external link), 500px (external link)
Maxum
May 21, 2012 05:54 |  #3
Thanks for the reply Red Snapper.
I use AI Servo because my subjects are moving.
Gatorboy
May 21, 2012 05:58 |  #4
Maxum wrote in post #14462259 (external link)
Then you should expect your lens to "hunt" all the time.
Dave Hoffmann
KVN ­ Photo
Joined Jun 2010
May 21, 2012 06:01 |  #5
Yeah, try to put it in 'one shot' and see if it could lock on the target.
X-Pro1 + 18-55 f/2.8-4 OIS + 55-200 f/3.8-4.5 OIS
TS-E 24 f/3.5L II + XF 35 f/1.4 + XF 56 f/1.2
Sony RX100 II + G12
Travel the world!
Maxum
May 21, 2012 06:15 |  #6
Ok, the subject is clearly in the center of lenses/view finder but refuses to lock on, hence my concern and it wasn't as bad as it is now. It is just a transitioning from one fuzzy blob to another fuzzy blob...continuously :)
I will try the 'one shot' later today...
Thank you all!!
Gatorboy
May 22, 2012 04:10 |  #7
Maxum wrote in post #14462305 (external link)
Ok, the subject is clearly in the center of lenses/view finder but refuses to lock on, hence my concern ...
Servo mode never LOCKS ... it's always focusing. Are you using the back button focus? If so, if shooting a static subject, focus and let off the button. You don't need it to keep "hunting", it's where it needs to be.
Dave Hoffmann
JohnB57
May 22, 2012 05:19 |  #8
Also, make sure you have the AF limit switch activated.
2,145 views & 0 likes for this thread, 5 members have posted to it.
1045 guests, 109 members online
