Just purchased a 32GB Sandisk Extreme 66mb/s UDMA CF card for my 5D2. It formats ok in camera but the picture count on the lcd is capped at 999. Should be close to 1200 I believe. Will a firmware update fix this?
ETS Senior Member More info | May 21, 2012 13:40 | #1 Just purchased a 32GB Sandisk Extreme 66mb/s UDMA CF card for my 5D2. It formats ok in camera but the picture count on the lcd is capped at 999. Should be close to 1200 I believe. Will a firmware update fix this? Fuji X-T2,5D MKII,Rebel XTi
Mistabernie 'Camera Unicorn McSparkles'.. More info | May 21, 2012 13:42 | #2 The LCD only has space for three digits - there's no physical place to put the fourth digit. While NOT looking at images/playback, hit the Info button twice, and you should get a true count on the main LCD on the back, bottom right hand side (I believe). The 5D3 has a space for a 1 on the top LCD next to the original count (999), so now it'll display counts up to 1999. Donate if you love POTN! | Smugmug
May 21, 2012 13:42 | #3 Nothing the actual LCD output is limited. When it goes to 998 you should have plenty of warning that you may run out soon.
May 21, 2012 13:50 | #4 Mistabernie wrote in post #14464020 The LCD only has space for three digits - there's no physical place to put the fourth digit. While NOT looking at images/playback, hit the Info button twice, and you should get a true count on the main LCD on the back, bottom right hand side (I believe). The 5D3 has a space for a 1 on the top LCD next to the original count (999), so now it'll display counts up to 1999. Ah, thanks so much! to both of you. Fuji X-T2,5D MKII,Rebel XTi
tagnal Goldmember 1,255 posts Likes: 64 Joined Aug 2010 Location: Bay Area, CA More info | May 21, 2012 14:01 | #5 silvrr wrote in post #14464022 When it goes to 998 you should have plenty of warning that you may run out soon.
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
| Latest registered member is semonsters 1462 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
