Thread started 22 May 2012 (Tuesday) 08:21
barrel change on ef-s 18-200 lens
etaf
May 22, 2012 08:21 |  #1
i just replaced my tamron 17-270 with a canon 28-200 = i was not happy with the quality of the tamron, turned out to have a fault
Anyway the 18-200 efs 3.5-5.6 IS lens
i notice that between 200& 170 zoom there's very slight movement in the barrel and also the image moves very slightly - between 18 and 135 a lot of barrel movement
is this normal ?
anyway to also test the IS
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
mwsilver
Gallery: 54 photos
Joined Oct 2011
May 22, 2012 21:38 |  #2
etaf wrote in post #14467898 (external link)
is this normal ?
The quick answer is yes. But it seems to vary some between examples. Mine is loose. I assume you're talking about barrel wobble rather than zoom creep, although my example also creeps very significantly. Not entirely sure what you mean by the image moving very slightly, but I'm guessing you're seeing the result of the image stabilization working through the viewfinder, which can cause a momentary and slight shifting of the image. I'm also assuming the barrel movement you refer to between 18 and 135mm is zoom creep. The 18-200mm zoom creep is significant in some examples, less so in others, The build quality of the 18-200 is OK, but not great. The focus is not full time and is noisy but it is not much slower than a USM motor and is definitely faster than the Tamron.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
eyalha
Joined Oct 2011
May 22, 2012 21:55 |  #3
I had the same issue, I just think that the zoom ring is inaccurate but that's just me
How do you find the change from the Tammy to the canon IQ wise?
5D2, 24-70L F2.8, Sigma 85 F1.4, Sigma 50 F1.4, 70-200L F4 IS, 100-400 F4.5-5.6 II, 430EX II X 2, A few Pocketwizards
mwsilver
Gallery: 54 photos
Joined Oct 2011
May 22, 2012 22:29 |  #4
eyalha wrote in post #14471441 (external link)
Not sure if you meant me or etaf since I also have a Tamron 18-270 PZD. I think the build of the Tamron is a bit better in some respects. The barrel is tighter. There is a lot less zoom creep and the extra 70mm is quite useful. Its much smaller and lighter. But the VC (Tamron's version of IS) is annoyingly noisy. The AF is quiet, but its not full time and is noticeably slower than the Canon 18-200mm. The lens which is f5.6 to f6.3 hunts often at the long end in low light. While the contrast is superior to the Canon, the Tamron is much softer then the Canon at the edges at most focal lengths. The Canon has more barrel distortion and Chromatic Aberration Due to the Tamron's size and weight, it would be a great match to any of the Rebels as well as the 50D and 60D.
Mark
etaf
May 23, 2012 02:06 |  #5
I agree with these statements, although only had the lens a couple of hours - also - I happened to put a new tamron on the camera and took my laptop in the shop so i could compare the results - the tamron was much softer and quite noticeable - just as soon as the images where side by side - even the shop manager was called over as they where surprised that the the canon is much better for me
i was referring to when you move the zoom from 170 - 200 the barral moved out only slightly and the image does not appear to move by 30mm
but that may be calibration
thanks for the replies
DC ­ Fan
May 23, 2012 05:15 |  #6
When using a Canon 18-200mm IS lens, I've been most interested in the pictures it generates such as these, instead of the positions of the barrels.
As long as the lens turns out images such as these, I'm satisfied. Pictures are what count, Everything else is trivia. The Canon lens is a pleasantly versatile and effective unit that works very well.
etaf
May 23, 2012 05:29 |  #7
i agree - but as i had a tamron 18-270 and changed yesterday to the canon lens (and they had no new ones in , only a 2nd hand one ) i wanted to be sure mechanically
while i take a few pictures over the next few days
so i would be interest in what happens to the barrel from 17-200 on the calibration markings on the lens itself, i have a few days to take it back
mwsilver
Gallery: 54 photos
Joined Oct 2011
May 23, 2012 10:04 |  #8
etaf wrote in post #14472542 (external link)
so i would be interest in what happens to the barrel from 17-200 on the calibrating markings on the lens itself, i have a few days to take it back
First, with regard to the small additional extension between 170mm and 200mm, that is normal. It only extends a short distance. The lens is designed to work that way. Stop worrying about the amount the barrel extends at any given focal length. Its not linear.
Second I'm assuming you're not familiar with zoom lenses, so pardon me if you are. Zoom lens are are designed based on focusing towards infinity. As a result, if you compare two different zoom lenses indoors, such as the 55-250mm kit lens vs the 18-200mm, and you focus on something indoors at the same focal length with each lens, say at 100mm, the size of the image in the viewfinder will likely be very different. This is not a calibration issue but is inherent in the design of zoom lenses. When focused on infinity, the images will be the same size. Those who do not understand this often think lens manufacturers are misleading customers when they specify the focal range of a lens.
Mark
etaf
May 23, 2012 14:04 |  #9
well, turns out the camera was not focusing correctly and unlike the 50D the 60D does not any adjustment for focusing
so we played with some bodies and lenses and replaced the body today
so more playing tomorrow
quite surprised my 50mm 2.5 macro lens appeared sharper that a 50mm 1.4 lens we tried
etaf
May 24, 2012 13:41 |  #10
just as an update , i went and saw a brand new 18-200 lens today in a different shop and its exactly the same very little change or movement between 170 & 200 - also took some images and they are the same so a much happier bunny today :)
also just realised my 2x convertor does not work on EF-S lenses :(
guess i will have to sell that along with a hoya 72mm and a hood - which i also got as part of the the trouble yesterday
4,204 views & 0 likes for this thread, 4 members have posted to it.
1228 guests, 137 members online
