Thread started 22 May 2012 (Tuesday) 15:23
exporting from aperture 3
suecassidy
May 22, 2012 15:23 |  #1
I have a 2.96 mb file in aperture that I want to enlarge and print. I processed it and exported that version to my usb stick using the "JPEG Original Size" but when it ends up on my stick or anywhere else, it is now a 998 kb file. Is that normal? I want to print it big and there isn't high enough resolution for a 16X20. What am I doing wrong? I've never had a problem with this sort of thing before....
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
tonylong
...winded
Gallery: 60 photos
May 22, 2012 16:49 |  #2
Sue, the file size is not just reflective of the resolution in pixels but also of the jpeg Quality setting that the software used when converting it -- it controls the amount of jpeg compression.
So, you want to look at your Quality setting. It doesn't need to be all the way to "Maximum" in order to get a good print, just something "High", although I don't have Aperture and so don't know the specifics.
Of course, having a lower resolution in pixels also affects the file size. You said you chose "JPEG Original Size", but you can double-check that just by opening the output file or checking its "properties" -- you can view the image dimensions in Aperture or iPhoto or wherever. I wouldn't be surprised if the image is in fact the "original size" in pixels, but that the Quality setting was lower than a "High" setting. If you put the quality to the Maximum, you'd end up with a very large file, even for an image that was down-sized for the Web!
Tony
suecassidy
May 22, 2012 18:47 |  #3
Thanks Tony. It never occurred to me that the preset could be set higher. I dug around and sure enough, the slider was set at 10, and the highest quality is 12, so I changed it and will see what happens. Thanks again.
Sue Cassidy
tonylong
...winded
Gallery: 60 photos
May 22, 2012 18:58 |  #4
suecassidy wrote in post #14470696 (external link)
Sounds good, Sue. For a print of any "size" larger than, say, an 8x10/6x9 I'd say yeah it won't hurt to max the slider, as long as the file sizes aren't beyond a limit that the vendor may have or be too cumbersom to upload.
But, you can experiment. Like I indicated, the max amount may not be really needed, although you can experiment -- if you set say a Quality of 11, you will cut down on the file size. View the image enlarged to approximate your print size, then try again with a Quality of 12, and compare!
Tony
René ­ Damkot
May 23, 2012 04:47 |  #5
suecassidy wrote in post #14469791 (external link)
Aside from what Tony explained: Neither the 1Ds nor the 1D3 have enough resolution for a "native" 300ppi 16x20" print: That would take 4800x6000 pixels.
So either you or the printer (company or machine ;)) will need to interpolate the file.
Not going to be a problem in my experience, but something to be aware of.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
suecassidy
May 23, 2012 11:47 |  #6
Rene and Tony, thank you so much. I'm too stupid for my life, clearly, because I didn't realize that the lab I used must have been interpolating this for me all along and I didn't realize it. I needed a cheap print quickly and was trying to send it to Costco online and didn't understand why it was telling me the resolution was too low. I'm a film girl from way back and when I run into problems like this that I can't figure out myself, and I need a quick answer, I have nobody to ask but the Canon forum! I DID change the image size as suggested and it worked; I'll pick the print up in an hour. Yay!
Sue Cassidy
2,055 views & 0 likes for this thread, 3 members have posted to it.
1684 guests, 140 members online
