Thread started 07 Dec 2005 (Wednesday) 16:37
Focus question: 1DsM2, 20D &10D.
Hatem ­ Eldoronki
Joined Jul 2003
Dec 07, 2005 16:37 |  #1
I posted this on DPReview, but then I'm not 100% satisfied with the replies..
I tested my 1DsM2 for backfocus using 4 lenses: the 50mmf1.4, 17-40, 100f2.8 and 28-135. For the test I used this chart (external link), at the bottom of the page.
All three cameras focus perfectly, when I'm close to the chart. Not when I'm far.
I noticed this also when shooting other objects, that I get backfocus when shooting a distant object. I always make sure I have enough contrast/lighting.
Could this happen? How could all 3 cameras perform similarly? If it's something wrong that I'm doing, then what is it?
1 D s M k I I
(Gear List Here)
 (external link)
defordphoto
MKIII Aficionado
Joined Oct 2002
Dec 07, 2005 16:59 |  #2
We would need to see some samples to comment. There are too many variables without seeing what you are doing. It is VERY easy to confuse the camera with these tests. Also be aware that AF is NOT an exact science and all camera makers state this as so. Just because you select AF does not mean every photo will be in focus.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
MDJAK
Dec 07, 2005 18:08 as a reply to  @ defordphoto's post |  #3
While RFM has given a very professional answer, and one that I completely agree with, let me give you my spin on it. I visited the website you linked. It's to a Noink website for the D70. THAT explains it in a nutshell.:)
Hatem ­ Eldoronki
Joined Jul 2003
Dec 07, 2005 18:13 as a reply to  @ MDJAK's post |  #4
I'm sorry, I don't understand..What does Nikon have to do with a test chart?
1 D s M k I I
(Gear List Here)
 (external link)
tim
Light Bringer
Dec 07, 2005 18:25 |  #5
Yeah like Jim says, post some examples for us to take a look at.
MDJAK
Dec 07, 2005 18:47 as a reply to  @ Hatem Eldoronki's post |  #6
The link you posted was from a Nikon enthusiast's website. I was only joking. Thus, the smiley face.
Hatem ­ Eldoronki
Joined Jul 2003
Dec 07, 2005 19:11 as a reply to  @ MDJAK's post |  #7
I could reeeaaaally be slow sometimes!
I'll post pics probably tomorrow.
1 D s M k I I
(Gear List Here)
 (external link)
Hatem ­ Eldoronki
Joined Jul 2003
Dec 10, 2005 15:55 as a reply to  @ Hatem Eldoronki's post |  #8
Sorry this took longer than expected, as I found out I deleted the files, so I took new shots today.
Here is where I focused: (50% crop)
http://www.artmaker.us​/test1.jpg (external link)
And here's the full image:
http://www.artmaker.us​/test2 (Large).jpg
BUT, when I focus on an object close to the lens, then I have no problems, as in the following image. How could this be possible? Could backfocus occur depending on the distance to subject?
No problems in this one (external link)
1 D s M k I I
(Gear List Here)
 (external link)
Hatem ­ Eldoronki
Joined Jul 2003
Dec 10, 2005 15:58 as a reply to  @ Hatem Eldoronki's post |  #9
AND, I apologize for the size of the images, although I think it's better this way.
1 D s M k I I
(Gear List Here)
 (external link)
defordphoto
MKIII Aficionado
Joined Oct 2002
Dec 10, 2005 16:41 as a reply to  @ Hatem Eldoronki's post |  #10
You need to limit photo sizes to 800 pixels on any one side, or (instead) post a link as edited above.
Hatem ­ Eldoronki
Joined Jul 2003
Dec 10, 2005 16:46 as a reply to  @ defordphoto's post |  #11
Done. Thank you.
1 D s M k I I
(Gear List Here)
 (external link)
SeanH
Dec 10, 2005 19:13 as a reply to  @ Hatem Eldoronki's post |  #12
I just read on Canon's site that the issues are the lens and not the bodies. this might explain why your results were the same regardless of the body you used.
That info is in here-
http://www.photoworksh​op.com/canon/EOS_Digit​al.pdf (external link)
7D ......waiting on the 5D3
10-22, 17-40 4.0 L, 24-70 2.8L, 70-200 2.8L, 2 X 580EX's
Tonky
Joined Nov 2005
Dec 10, 2005 19:58 as a reply to  @ SeanH's post |  #13
The link to your full image isn't working and the quality of your smaller pic isn't very clear. However, looking at the selected AF point it appears to be partly covering two boxes which wouldn't be a problem as long as both boxes were at exactly the same distance from the camera. It does appear though that the right hand corner of the upper box may be slightly closer to the camera?
More significantly, there appears to be a piece of card or paper sandwiched between the two boxes which is also within the selected AF area which is protruding out quite some distance, and is closer to the lens than both boxes. If this is so then look no further for the cause of your focusing problem as no AF system can focus on two, possibly three planes at once.
Hatem ­ Eldoronki
Joined Jul 2003
Dec 11, 2005 05:07 as a reply to  @ Tonky's post |  #14
Tonky wrote:
The link to your full image isn't working ...
Fixed. Here it is again anyway (external link).
1 D s M k I I
(Gear List Here)
 (external link)
Hatem ­ Eldoronki
Joined Jul 2003
Dec 11, 2005 05:12 as a reply to  @ Tonky's post |  #15
The boxes are almost at the same distance from the camera, which, and I am just guessing is about 25 feet.
However, look in the direction of the refrigerator. Does it appear sharper?
1 D s M k I I
(Gear List Here)
 (external link)
3,186 views & 0 likes for this thread, 7 members have posted to it.
1460 guests, 130 members online
