Thread started 25 May 2012 (Friday) 04:20
Reverse engineering needed :)
coldplug
May 25, 2012 04:20 |  #1
Hello.
I'm trying to achieve processing effect like this, but I have no luck. Any idea what has been done to this image? Thx
http://www.facebook.co​m …9303416737&type​=1&theater (external link)
Lowner
"I'm the original idiot"
May 25, 2012 06:58 |  #2
Being there at the right time?
Richard
RichSoansPhotos
May 25, 2012 07:44 |  #3
Its not only done by photoshop, its done with filters which are better than "digital filters" as those found in photoshop and other editing software
coldplug
May 25, 2012 08:42 |  #4
Lowner wrote in post #14482756 (external link)
Of course, without that nothing, but I'm referring to the characteristic tones/colour of the image that I can't find almost anywhere among other authors.
His whole gallery has that unique look, but mostly you can see it on examples like these:
http://www.aleksandarg​ospic.com …llery=4e3ec714a​3da7&tags= (external link)
etc.
What I refer to is.. dark shadows, that almost looks desaturated and colorful midtones. But when I try to do that (boost contrast, desaturate shadows...), I don't get even similar results. It must be something else here. Also boosting saturation does not give colorful results like this. I have pretty good SLR equipment and shoot in RAW, and go to same places as this photographer do (I know him personally :) ), but my pictures comes not even close to this even if I try to actually copy his results.
400dabuser wrote in post #14482900 (external link)
I didn't mentioned neither photoshop, neither digital filters :) What do you suggest? However, I doubt he use any special filter in the field except polarizer and sometimes graduated ND.
kirkt
May 25, 2012 09:10 |  #5
Do you have an image of yours that you want to use to try to achieve the same look? Post it here and let folks have a whack at trying to emulate the photographer's look. Also, if you know the photographer, you may want to ask him.
kirk
Kirk
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 25, 2012 09:39 |  #6
Besides "Being there at the right time?", he's probably blending the best part of two/several RAW conversions together. It's really simpler than it looks. Look at Three pages on Layer Masks (external link)
Adjustment layer basics (external link)
More in post #8: Tough Exposure question
coldplug wrote in post #14483054 (external link)
Seems as if you'd save a LOT of time by just asking him what his process is?
coldplug
May 25, 2012 09:53 |  #7
kirkt wrote in post #14483170 (external link)
kirk
This is good idea!
Let's try!
First goal:
http://a8.sphotos.ak.f​bcdn.net …37_919872_83956​1556_n.jpg (external link)
Source:
http://www.meteoadriat​ic.net/pub/potn/_DSC66​92.NEF (external link)
(I know, Nikon, D700 and he has also Nikon (D300) so it should be even easier to get it). This one is not exactly the same frame but it is very much it.
Second goal:
http://a1.sphotos.ak.f​bcdn.net …7_919077_180501​6681_n.jpg (external link)
Source:
http://www.meteoadriat​ic.net/pub/potn/_DSC66​50.NEF (external link)
This is completely same framed shot, same lens, only body is different (D700 vs D300). No filters attached on lens on either examples.
PhotosGuy wrote in post #14483285 (external link)
Thanks, I'll look at this :smile:
Won't work, he is one of those secret keepers :lol:
alpine2306
May 25, 2012 10:00 |  #8
Some great information in these threads.
Subscribed!
kirkt
May 25, 2012 20:49 |  #9
coldplug wrote in post #14483355 (external link)
Buy him beer.
Kirk
kirkt
May 25, 2012 21:14 |  #10
You probably want to convert the raw with a neutral tone and color to start. Then slam the contrast and saturation. THis will result in very deep blue shadows that may plug up more than desired. You can use the Shadows/Highlights tool in PS to lift the shadows back to a desired range and use the Color Correction slider with negative values to desaturate the blue out of the shadows.
kirk
Kirk
lensfreak
Joined May 2012
May 26, 2012 03:26 |  #11
I would thing to slightly desaturate the land and selectively saturate the colour of the sun. Have done with some landscapes before and seems to work well. Possibly a slight bit of dodging on the landscape..
Denis
coldplug
May 26, 2012 04:57 |  #12
kirkt wrote in post #14485729 (external link)
kirk
Hmmm this does the good job toward wanted result. However, lot of tweaking after that I had to perform, I spent about 20 minutes to tune the image so it looks pretty much close to goal. But still thanks, this approach with overcontrasting and then getting back some shadows while in the same time desaturating them with Color Correction looks promising, thanks!
proximustherogue
Joined May 2011
May 27, 2012 02:49 |  #13
can we some of the progress anyone is making with these?
get out and shoot
Radtech1
Everlasting Gobstopper
Joined Jun 2003
May 27, 2012 17:29 |  #14
Without standing over his shoulders, it is a tough call. As mentioned by others, it looks like some selective desaturaiton is involved as explaining at least part of the results.
If we give the guy the benefit of the doubt, and make the assumption that the sky/reflection WAS NOT created, and that it does represent the actual colors at the time of the shot, then I would thing that there was some exposure bracketing as well.
When shooting in the direction of a sunset - as this one is* - and the shaded foreground is properly exposed, the sky stands a good chance of being washed out. When the sky is properly exposed, the foreground is most often too dark. This can happen even if you are not shooting at the sun itself A clear sky in the same general direction as the sun can be several steps brighter than the ground.
Multiple exposures of the same scene with different exposure factors can give you at least a couple of shots properly exposed for each area - sky and ground. Put them together in PS and you will be able to show a dynamic range that you would not otherwise be able to with just one press of the shutter.
Here is a sunset shot that I took near Stuttgart. The sun is somewhat obscured by clouds, so it is less intense than it might have been. Still, the when exposing for the foreground, the sky is nearly whited out. In the example you linked to, I would expect the sky to look somewhat like this when the foreground is well lit. No amount of post will give the sky the intensity of your example if it is not there in the first place.
IMAGE: http://s19.postimage.org/7fl2r9z77/SS1.jpg
My next shot shows what the foreground looks like when the sky is properly exposed. Nearly black, without any contrast or definition. If you tried to pull this up in post, the results are nearly always unacceptably grainy.
IMAGE: http://s19.postimage.org/p71ajh3zn/SS2.jpg
But, blend the two in photoshop, add a little saturation and local contrast, and the result is a pretty good sunset shot! (For printing, I added some blue to my sky, which can be seen here, but the bracketing/blending point is the same.)
Rad
IMAGE: http://s19.postimage.org/y3c2neulv/SS3.jpg
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
masterg
Joined Jun 2011
May 27, 2012 21:02 |  #15
it almost seems like an HDR photo. a lot of the photo seems to be in focus to me, but seems to be too great of depth to accomplish in 1 photo. You would as others have said, layer multiple focused photos on each other
3,467 views & 0 likes for this thread, 10 members have posted to it.
1396 guests, 165 members online
