Thread started 26 May 2012 (Saturday) 01:31
Which batteries for on camera flash
wickiup
May 26, 2012 01:31 |  #1
I am using a Canon Speedlite 430 EXII (Or trying to).
It seems the batteries are continually dead after only taking a half dozen shots then let it set a couple of days of none use.
I am using Energiser 2450's which last forever in a P & S.
Any ideas would be great
Jim
mike_d
May 26, 2012 01:36 |  #2
If Google led me to the right item, your batteries should be 2450 mAh NiMH batteries. That should provide plenty of power unless they're defective. I use 2000 mAh Sanyo Eneloops and can get a few hundred shots out a set in my 580EXII flash, even when using high speed sync which really draws a lot of power. How old are your batteries? Maybe they're worn out.
bratkinson
Joined Dec 2011
May 26, 2012 04:12 |  #3
I switched to Eneloops from Energizer Bunnies in my 580 EX II and the difference was like night and day. Faster recovery, more shots before recovery slows down. The Eneloops keep flashing, and flashing, and flashing...
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
saea501
... spilled over a little on the panties
Gallery: 43 photos
May 26, 2012 06:51 as a reply to  @ bratkinson's post |  #4
I use the Energizers in my 430 EXll and they work quite well. Last a long time in use or not.
As mentioned above maybe yours are shot. Although I have one set that I have been using for more than two years and they still work fine. But from your description something is surely not right.
I would just replace them.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
wickiup
May 26, 2012 12:51 as a reply to  @ saea501's post |  #5
Thanks Guys,
The batteries are not new and perhaps the extra load is using them up more than usual.
Would like to hear more about the Eneloops.
Jim
shutterpat
Gallery: 33 photos
Best ofs: 11
May 26, 2012 13:05 |  #6
You can't go wrong with the loops :cool:
Got Loop? (external link) by OC PAT (external link), on Flickr
Meanderthal
May 26, 2012 15:45 |  #7
I use Imedions. You may find this thread useful:
https://photography-on-the.net/forum/showthre​ad.php?t=677074
http://spitzhaven.zenf​olio.com/ (external link)Photo gallery (external link)
wickiup
May 29, 2012 01:02 |  #8
Meanderthal wrote in post #14488499 (external link)
Ah, yes, very useful indeed!
Jim
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 29, 2012 08:35 |  #9
I have heard a lot about Eneloops and I probably would have picked them up if I had read forums before purchasing. I have seen this battery suggested so many times I doubt you will go wrong.
I went to our local ma & pa camera store and they sell Ansmann. They are 2500 mAh NiMH batteries and I can't compare them to Eneloops but my guess is they are just as good. Slow discharge and they just keep firing. I have 3 sets of 2500 mAh NiNH and one 2100 mAh NiNH back up set. I usually use two cameras and two flashes at events. I have yet to have use my 2100 mAh NiNH back up set or open the back up, to the back up :D set of alkaline I keep around. They just keep firing.
A note on the energizer non chargeable style of batteries. The store told me that they do not provide the full power that flash requires or can handle. Can't remember the details as this was a few years ago. I do know alkaline batteries I used had a far slower recycle rate. I did not believe them at first but I can't believe how amazing NiNH rechargeable batteries are. I have saved a ton of money and the environment as well as a little of a dent I have made in that department.
Image Editing OK
btmlinedan
May 29, 2012 08:46 |  #10
I use powerex 2700mAh's and Imedion 2400mAh's.
The regular powerex's have a little bit more capacity but the imedions are great b/c after AN ENTIRE YEAR of sitting they are still at 85% capacity (very low drain). I usually have the powerex's charged up right before a wedding, and keep the imedions ready for backups.
I used to use NIZN (nickel zinc) which the recycle time was amazing, (youtube them) but I had a few issues with the charger or a single cell dying, so they've been replaced by more imedions. Currently NIZN's have stopped being made until they can fix some internal issues (says the company, yes I called :) )
HTTP response: 403 | MIME changed to 'text/plain'
I also use the powerex smart charger which can recondition and slow charge. I highly recommend it.
*dan l *Flickr (external link) l *cars: dkfx Photography (external link) l weddings: Blue Martini Photography (external link) l YN622C tranceiver review (external link)
gremlin75
May 29, 2012 11:31 |  #11
patrickf117 wrote in post #14487971 (external link)
Agreed (I actually use "duraloops"....they are just eneloops repackaged by duracell)
Logicus
Joined Nov 2010
May 29, 2012 11:44 |  #12
I'd read a good bit about and wanted to get the eneloops, but no one carries them anywhere near me, and I needed batteries fast, so I bought a bunch of energizer 2300's. I shot a wedding, left them in the flash for about a month and a half, and then used them in a cave in southern ky, then again at a party and the same 4 are still in my 580EXII. I haven't noticed issues with recycle times, and certainly not with long-lasting ability. Just my $0.02.
My Gear List
My flickr (external link)
My flickr photos organized by Lens Used (external link)
Joe ­ Ravenstein
May 29, 2012 13:47 |  #13
Go online to buy eneloops, several places have free shipping and decent prices on them.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
davisphotos
May 31, 2012 14:36 |  #14
Eneloops or Powerex, I have both and they are great, I can get through almost a whole wedding with one set of AAs in my 430EX. Had some Energizers that did end up not holding a charge after a while, although that may have been my charger. I now have the same Powerex that Dan has, and I've had no failed batteries for a while.
Maine Wedding Photographer Andrew Davis (external link)
New England Commercial Photography (external link)
Andrew Davis Photography Blog (external link)
2,396 views & 0 likes for this thread, 12 members have posted to it.
1739 guests, 171 members online
