Thread started 29 May 2012 (Tuesday) 13:25
5D3 Oddity
timnosenzo
May 29, 2012 13:25 |  #1
I already sent Canon an email about this to see if they think I should send the camera in or not - but I figured I would post it here to see if anyone has had a similar issue with their 5D3.
During an engagement shoot this past weekend, I noticed 2 files seemed corrupt. I copy full RAW files to both the CF and SD cards, and the same images on both cards look the same way. They appear the same when reviewed on the camera LCD as they do in the screen shot below.
Luckily the 2 photos are throw-aways anyway, but it could have easily been an important moment during a wedding.
IMAGE: http://www.timnosenzophoto.com/photos/i-6xp5JWd/0/XL/i-6xp5JWd-XL.png
Andrew_WOT
May 29, 2012 13:26 |  #2
The issue was fixed with the firmware upgrade.
timnosenzo
May 29, 2012 13:29 |  #3
Andrew_WOT wrote in post #14501016 (external link)
Hm... I'd have to double check the camera but I'm pretty sure they're all running 1.1.2 (which I believe is the latest).
Kechar
Joined Mar 2011
May 29, 2012 14:07 |  #4
I know some teens that would pay for that effect! :lol:
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
timnosenzo
May 29, 2012 17:21 |  #5
Just checked, the cameras all have the latest firmware.
What's interesting is that the two images actually seem like they're both the same. The photo was part of a sequence and when I flip back and forth between these two, they're exactly the same. Weird. :confused:
Andrew_WOT
May 29, 2012 17:58 |  #6
timnosenzo wrote in post #14502223 (external link)
It is weird as it's in the list
http://www.photography​bay.com …are-update-version-1-1-2/ (external link)
-Fixes a phenomenon where a pink cast may develop over the image when the shutter is completely pressed with the camera’s power turned off (by the auto power off setting).
timnosenzo
May 29, 2012 18:25 |  #7
Andrew_WOT wrote in post #14502386 (external link)
But this says:
I didn't have the power turned off or anything - I was in the middle of a sequence of 20 images.
Stuperfox
Gallery: 12 photos
May 29, 2012 20:14 |  #8
Looks like a file writing issue to me. Since the images seems to be overlapped. Though it could be you just found another issue with the new firmware. If so congrats, you have now be first to wait for the new firmware.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
wvo
May 29, 2012 21:01 |  #9
I ran into a similar issue a few weeks ago also. Latest firmware, images 8 and 9 out of 11 shots.
IMAGE: https://dl.dropbox.com/u/22176/5diii.png
omegaone
Joined Apr 2012
May 29, 2012 21:10 |  #10
I'm kinda sure it's a memory card problem, not the camera
Try to replace the memory card and see how it goes
Canon 5D3 | 17-40 f4L | 24-105 f4L IS | 70-200 f2.8L IS II | 85 f1.2L II | 100 f2.8L IS
Flashes: Phottix Indra500 | 580EX I | 580EX II with Phottix Odin and Godox Winstro AD360
Fuji XT1 Black | | Fujinon 18-135 f3.5-5.6 OIS | Fujinon 10-24 f4 OIS | Fujinon 56 f1.2
Erwin Sajudi Photography (external link)
timnosenzo
May 29, 2012 21:12 |  #11
wvo wrote in post #14503200 (external link)
Interesting.
omegaone wrote in post #14503239 (external link)
I'd agree with you if the images on both the CF and SD card weren't the same.
elrey2375
Thinks it's irresponsible
Joined Nov 2011
May 29, 2012 21:24 |  #12
If it's only happened the one time, I wouldn't be panicking too much. Let's not throw out the baby with the bathwater.
http://emjfotografi.co​m/ (external link)
http://500px.com/EMJFo​tografi (external link)
elrey2375
Joined Nov 2011
May 29, 2012 21:25 |  #13
They're not exactly the same. The strip at the top is different.
sonnyc
Joined Jun 2005
May 30, 2012 01:43 |  #14
I have this pink cast with RAW file when using the default win7 viewer once in a while but LR shows it fine. It only happened with Raw and not JPG.
Sonny
Eyal
Joined May 2011
May 30, 2012 02:04 |  #15
4x4rock wrote in post #14504340 (external link)
I have the same issue when viewing the raw files in picasa, win 7. LR shows them correct.
But the OP says they look like that in the camera, so I'm not sure its the same.
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
5,079 views & 0 likes for this thread, 9 members have posted to it.
5D3 Oddity
1048 guests, 115 members online
