Thread started 29 May 2012 (Tuesday) 15:18
Sandisk SDHC card question
Shutterwolf
Joined Apr 2012
May 29, 2012 15:18 |  #1
I am looking at the 45MB/s cards and the 95MB/s cards and wondering if you get much of a boost in write speed from the camera between the 2, or is the 45 good enough and the 95 is just for download speed to the computer?
Also, I am trying to decide between 2 16gb cards or 1 32gb card. I plan on shooting mostly RAW, but also RAW + Jpeg at times, with some video once in a while as well.
Also, I read somewhere that with the video, you can only record up to 4gb at a time on the 60D? Why in the hell would they limit it to 4gb? That doesn't make any sense to me at this point.
Another question... How many pictures can you fit on a 16gb card using RAW only with a 60D? I could probably find that somewhere on google, but it doesn't hurt to just ask someone on here either lol.
Josh
https://www.facebook.c​om/ShutterwolfPhotogra​phy (external link)
60D, 550EX, Canon EF 50mm f/1.8 Mark II, Canon 28-135mm IS, 18-55(old), Rebel Xti/400D (for sale)
ShockFactor03
May 29, 2012 16:53 |  #2
I recommend getting the fastest and largest capacity you can afford.
You will notice the difference if you shoot lots of burst shots. I see you have the 60D, and the raw files are approx. 18 - 25.5 megs each. So you hold down the shutter for say, 10 shots, and you have about (10x25=) 250-some megs writing to the card in like 2 secs. The 95MB/s cards will handle that with zero or little buffer lag. You will also transfer data faster, depending on your card reader, or however you transfer your files to a pc.
I have a couple 16G and 32G
SanDisk SDSDRX3-016G-A21
SanDisk SDSDRX3-032G-A21
I'm now using these (I like these a lot)
SanDisk SDSDXPA-064G-A75
The Extreme Pro's are expensive, but they do what they claim so I'm happy.
The video length has to do with FAT table limitations. Newer cameras like the 5D mkIII can record up to 29 mins per shot. I use my 60D for video occasionally. I get approx 8-11 mins, closer to 11, on full HD setting, per shot.
Gear
Wilt
May 29, 2012 19:20 |  #3
Rob Galbraith has been promising test results for memory cards for both the 50D and the 60D for months now. First they were to be published by end April, now the site promises end May.
The 7D is tested with both CF and SDHC. The best CF writes JPG at 45MBytes/sec while the best SDHC writes at 17 MBytes/sec. A 150x memory and a 600x SDHC is no faster than a 133x memory SDHC in write speeds. So it seems that the 7D camera itself is the limiting factor!
The 5DIII is similar, with CF it tests JPG write at 46.8 MB/sec, but with SDHC it tests to only 17MB/sec; with RAW it tests on CF to 80MB/sec but with SDHC it limits at 20MB/sec..
Whether or not the 50D and 60D are any better remains to be seen.
SDHC is handicapped by the fact that it is a serial device (one data line), while CF is parallel port memory (many data lines)
Shutterwolf
Joined Apr 2012
May 30, 2012 05:05 |  #4
Ok, well in that case...What is the best deal I can find on a 32GB 45MB/s or 95MB/s card? So far, B&H looks to be the best, unless someone knows of one better.
Josh
jbrackjr
Joined Dec 2011
May 30, 2012 06:50 |  #5
Amazon put the SanDisk Extreme 32GB 45MB/s SDHC Flash Memory Card SDSDX-032G-X46 on sale for $35 on May 22. It is now $39 delivered (if your prime). Adorama and B&H is about $42.
Jim
Wilt
May 30, 2012 10:25 |  #6
Shutterwolf wrote in post #14504687 (external link)
Why waste any money on SDHC memory with write speeds faster than 20MB/sec, since the testing by Rob Galbraith has never shown effective speeds higher than that threshold? It might cost more, but there will be no improvement in performance in camera.
Admittedly, memory read speeds could hasten data transfer from memory to PC, if the reader or the PC is not the gating item.
2,087 views & 0 likes for this thread
Latest registered member is aggrey12
1206 guests, 236 members online
