Thread started 29 May 2012 (Tuesday) 15:30
Debating what to do with my lens situation..
Shutterwolf
Joined Apr 2012
May 29, 2012 15:30 |  #1
i recently sold my XTi with the 18-55 kit lens that wasnt IS. I used that lens quite a bit, but it was a friend buying this as his first camera, so I wanted him to have a lens and I want the IS version anyway...
My dilema is, would it be best to just buy a used 18-55 IS here, OR sell my 28-135 and get the 18-135 all in one... that or the 18-200. Not sure which combination would be best.
I have also considered getting a 70-200 or 70-300. Possibly a 100-400. Of course those will have to wait for a long time, but they are on the dream list right next to a good macro lens. Could really use some good advice here.
Thanks in advance for your time!
Josh
https://www.facebook.c​om/ShutterwolfPhotogra​phy (external link)
60D, 550EX, Canon EF 50mm f/1.8 Mark II, Canon 28-135mm IS, 18-55(old), Rebel Xti/400D (for sale)
L.J.G.
"Not brigth enough"
May 29, 2012 15:37 |  #2
If it was me I would sell the 28-135, buy a Canon 17-55 and a 70-200 F4 IS. The Canon 15-85 is another option if you did not want the constant F2.8 of the 17-55. You would have a good combo then that covered quite a range.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
Shutterwolf
Joined Apr 2012
May 29, 2012 16:02 |  #3
L.J.G. wrote in post #14501737 (external link)
I would love to, but money is a bit of an issue. Looking for an inexpensive way to do thing for now. Some day in the future I would love to upgrade to better glass, but for now I just need something to replace my 18-28 range. I would just go for a 10-22, but that is also a bit out of my reach for now.
Josh
1Tanker
May 29, 2012 16:05 as a reply to  @ Shutterwolf's post |  #4
Then an EF-S 18-55 IS is your best bet... til you can afford to upgrade.
Kel
Gear
Shutterwolf
Joined Apr 2012
May 29, 2012 16:18 |  #5
1Tanker wrote in post #14501884 (external link)
Well that or the 18-135 if i sell my 28-135. Or is the 28 a better lens?
Josh
1Tanker
May 29, 2012 16:23 |  #6
Shutterwolf wrote in post #14501941 (external link)
Yes, you could do that as well.. if you can afford it. The 28-135 has USM AF(a great feature) and better build. It also has zoom-creep, as i'm sure you realize, but if you never mentioned it.. it probably isn't an issue for you. You're looking at close to $500 for a new 18-135.
Kel
Gear
watt100
May 29, 2012 16:29 |  #7
the 28-135 is significantly worse in resolution or "sharpness"
http://www.the-digital-picture.com …omp=0&FLIComp=6​&APIComp=1 (external link)
or
www.photozone.de (external link)
The 18-55IS and 55-250IS is the best in the "value/performance" combination, look at used in the buy/sell section
Craign
Gallery: 17 photos
May 29, 2012 16:44 |  #8
Cheapest: Sell your 28-135 ($200) and buy a used 18-135 ($250) net cost around $50 Some great deals possible for $250 or less on virtually new out of kit lenses. My first choice.
Keep the 28-135 and buy a used 18-55 for about $100 (Make sure it is the EF-S 18-55mm f/3.5-5.6 IS II version)
More expensive:
Buy new EF-S 18-55mm f/3.5-5.6 IS II for about $200
Buy an 18-200 Used seem to be around $400 Sell 28-135 and net cost would be around $200
Start a good savings program for the more expensive lenses you mentioned. Stick to it! Save $20 per week and you will have over $1000 in one year. That means segregated funds, not saving in your mind or hoping your checking account will grow. One $20 bill per week in a box works.
Canon 7D Mark II w/Canon BG-E16 Battery Grip; Canon EOS 50D w/Canon Battery Grip; Canon SL1; Tokina 12mm - 24mm f/4 PRO DX II; Canon EF 24-105mm f/4L IS; Canon EF 70-200mm f/2.8L IS; Canon 70-300mm f/4-5.6L IS; Sigma 85mm f/1.4 EX DG HSM; Canon EF 300mm f/4L IS; Canon EF-S 18-135mm f/3.5-5.6 IS STM; Canon Extender EF 1.4x II; Canon Extender EF 2x II; Canon Speedlite 430EX II Flash
Image Editing Okay
Scott ­ M
Gallery: 83 photos
May 29, 2012 16:57 |  #9
How about the non-IS version of the Tamron 17-50mm f/2.8? It should fit within your budget, especially if you sell the 28-135mm. If you also need more reach, then add a EFS 55-250mm telephoto with the funds from the sale of the 28-135mm.
Photo Gallery (external link)
1Tanker
May 29, 2012 17:20 |  #10
Craign wrote in post #14502058 (external link)
More expensive:
There's virtually no difference between the Mk 1 and Mk II of this lens.. just that the Mk II is slightly newer. A good deal on a Mk 1 will be fine as well.
Kel
Gear
nightcat
May 29, 2012 19:01 |  #11
Scott M wrote in post #14502126 (external link)
great suggestion, great lens, and it's cheap.
DreDaze
Gallery: 49 photos
May 29, 2012 19:13 |  #12
what is your budget exactly? you could look at a sigma 10-20mm to cover the wider end...
Andre or Dre
gear list
Instagram (external link)
pbelarge
Joined Jun 2010
May 29, 2012 19:18 as a reply to  @ DreDaze's post |  #13
What exactly are you shooting?
What style of shooting do you do?
It would help to know.
just a few of my thoughts...
Pierre
duane0524
May 29, 2012 19:46 |  #14
How much can you spend? What about keeping your 28-135 and adding a used Sigma 10-20mto fill the void and give you even more?
Canon 50D | Canon 17-55 | Sigma 30 1.4 | Canon 70-200 2.8 IS II| Canon 85 1.8 | 430EXII| 580EX ll | ST-E2 | Canon TC 1.4x II | Benro Travel Angel C1682TB0
Shutterwolf
Joined Apr 2012
May 29, 2012 23:12 |  #15
DreDaze wrote in post #14502688 (external link)
duane0524 wrote in post #14502830 (external link)
pbelarge wrote in post #14502707 (external link)
I do nature and dog photography mostly. Also random fun stuff here and there. Always looking to expand my ability, tho I'm not really interested in human photography. I have never been very creative or good at it. Dogs are my strong point, and other animals I'm descent with. I really like having a close range lens, and a wide angle would be lots of fun.
How much is the Sigma 10-22 and how does it compare to the Canon? The 1 sigma lens I have tried at a camera shop was slow and noisy for focusing. Forget what it was though.
Josh
2,527 views & 0 likes for this thread
Latest registered member is Lettuceboy95
843 guests, 240 members online
