Thread started 30 May 2012 (Wednesday) 18:59
The best cable release for 5D II, III, 7D!
tvphotog
May 30, 2012 18:59 |  #1
It only took two years of the cable coming loose from the left side port of my 5D2 and 7D, just when I had the perfect shot. The shutter would not fire as a result. I had bought a couple of cables from HK in the past, all had the same problem. I've heard that the Canon cable has the same issue.
I posted about it a week ago and a couple guys said, 'yeah, these are all bad cables, doesn't matter whether it's a Canon or a Chinese knockoff, and they're probably made in the same factory '. I was very frustrated, but based on good reviews on B&H, I took a chance and bought a couple of the Vello releases (external link) there.
They are perfect. They fit so tight, you have to give them a little pull to release them. The reason is in the photo below.
The length of the male connectors to the camera pins, the first part of the connector seen facing one another, looks a little longer on the loose cable on the left, compared to the Vello cable on the right.
However, the difference is because of the length of the collar of the connector which holds it in the port. On the left with the red arrow, you'll notice it's only about a 16th of an inch wide on the bad cable. On the Vello with the blue arrow, it's about a quarter inch. That extra length holds it tight. The actual pin connector is also a bit longer on the Vello, to accomodate the wider collar.
$7.50 at B&H. The Canon is about $40.
Also will post this on the "coolest accessories" thread.
IMAGE: http://i17.photobucket.com/albums/b87/maxselma/Cable.jpg
Photo below courtesy B&H
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/05/5/LQ_598561.jpg
Image hosted by forum (598561) © tvphotog [SHARE LINK]
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
westcliff
Joined Apr 2012
May 31, 2012 09:58 |  #2
Wow, perfect timing. I finally decided to buy a cable release for my 5D2 and was looking at non-Canon options last night, so this report and recommendation couldn't be more timely. Thank you!
craig_k
Joined Mar 2012
May 31, 2012 10:23 |  #3
i purchased the vello rw2-c freewave plus from b&h for use with my 7d and 50d bodies ...it works fine, no issue...never used anyother brand bdfore,first purchase of remote anything...fwiw
feedback: [URL]http://photograph​y-on-the.net/forum/showpost​.php?p=15029315&postco​unt=36656
feedback: [URL]http://photograph​y-on-the.net/forum/showthre​ad.php?t=28608&page=25​83
feedback: [URL]http://photograph​y-on-the.net/forum/showthre​ad.php?t=28608&page=25​93
nice bodies, L-lenses, rrs, 1600 alien bees,pelican cases..."lots of try"
rick_reno
May 31, 2012 11:25 |  #4
excellent, mine has been loose too. i'll grab one of those today. mine (a cheap Chinese knockoff) looks just like the one with the red arrow in your photo.
bps
May 31, 2012 12:19 |  #5
I own a wired Vello and a wireless Vello Freewave Plus. Both are excellent products, especially for the price, however, there is one minor issue that everyone should be aware of.
The longer collar on the Vello (look at the blue arrow in Jay's original post) causes the shutter release to extend a little further out than the shorter one. If you use a RRS L bracket on at the 7D, then you will have to slide the L bracket to the left in order to shoot in portrait orientation on your tripod. I simply slid my L bracket to the left by about 1/4 to 1/3 of an inch and I've kept it there ever since. This makes the camera feel a little bigger since the L bracket is extended out to the side. It's not too big of a deal and I've gotten used to it, but it is something to consider.
In spite of that minor issue, the Vello shutter releases are very inexpensive and built really well. I highly recommend them, as long as you don't mind having to slide your L plate over a little bit.
Bryan
My Gear List
tvphotog
May 31, 2012 14:02 |  #6
bps wrote in post #14511783 (external link)
Bryan
I've done as you have with the bracket, moved it out and left it in that location. For me, it's easier than having to remember to take the hex wrench with me, or to curse that I forgot it!
Jay
Jon
Joined Jun 2004
May 31, 2012 14:07 |  #7
tvphotog wrote in post #14512246 (external link)
Victorinox Swiss Army Cybertool. It includes just the right size hex bit for your RRS bracket, along with those other essential tools the bottle opener and corkscrew. I understand it has a knife blade as well :{)#
Jon
Cocker Spaniels
Saint728
May 31, 2012 14:29 |  #8
I've only used the Canon Timer Remote Controller TC-80N3 for the past 4 years and it still fits super tight. In fact I have a hard time pulling it out. I use it a couple times a week.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
RSMarco
Joined Oct 2011
May 31, 2012 14:30 |  #9
Interesting. Shame I'm in the UK.
Camera Gear: Canon 5D MKIII | 24-105 f/4 L IS USM | 16-35 f/2.8 L II USM | 70-200 f2.8 L II IS USM | Canon Speedlite 580EX II
Computer / Software: Apple iMac 27" | Adobe CS5.1 | Adobe Lightroom 4
tvphotog
Jun 01, 2012 10:44 |  #10
RSMarco wrote in post #14512345 (external link)
Vello is HK. I'm sure some camera shop or Amazon has it over there.
Jay
rick_reno
Jul 23, 2012 19:33 |  #11
Just got mine. A much better fit than whatever Chinese one I had, a nice snug fit. I like the packaging too.
westcliff
Joined Apr 2012
Jul 24, 2012 09:15 as a reply to  @ rick_reno's post |  #12
Have been happily using my Vello wired cable release since early June thanks to the OP's recommendation. Good fit, works well.
spotz04
Oct 06, 2013 07:12 as a reply to  @ westcliff's post |  #13
My review -- I've had my Vello since March 2012, bought from B&H, and it got a lot of use. The connector would not always stay in the socket on either my 7D or the 5DII, many times even pulled out in landscape mode. While in portrait mode the connector would sometimes slip out. Not fun when working in the dark shooting star trails or the Milky Way. :lol: Anyway, my cable release eventually broke last night -- there's a break in the wire on the thicker grooved rubber area that connects outside the handset. Press the shutter release, nothing - but if I wiggle the wire at that section then it triggers the shutter. Problem repeats consistently. I removed the two screws to open and see if possibly the wires came loose internally but that wasn't the case.
windpig
Chopped liver
Oct 06, 2013 07:25 |  #14
Hmm, I've been using one I bought from Adorama 4 years ago and still tight. Then again, it's a wireless unit, so once it's on it doesn, t get moved unless I chance the camera orientation.
Go ahead, spin the wheel.
spotz04
Oct 11, 2013 06:49 as a reply to  @ windpig's post |  #15
I bought a Pixel brand from Amazon for less than $8.00, connector fits the socket very tight, it's the same length as the Vello --
http://www.amazon.com/​gp/product/B005TCOQIQ/ (external link)
9,917 views & 0 likes for this thread, 12 members have posted to it.
1109 guests, 123 members online
