Thread started 31 May 2012 (Thursday) 09:45
Picture Package feature in CS6
Shooting
May 31, 2012 09:45 |  #1
Has been removed and the layouts and plugin for it you can get for CS5 does not work.
Anyone know how to make picture packages in CS6?
Thank you.
tonylong
...winded
Gallery: 60 photos
May 31, 2012 15:11 |  #2
I don't have CS6, so I Googled "photoshop cs6 picture package" and there seems to be good info out there:
http://search.comcast.​net …package&top_Sea​rchSubmit= (external link)
Tony
Shooting
Jun 01, 2012 16:07 as a reply to  @ tonylong's post |  #3
Yeah, from what I read, Adobe abandoned the picture package layout in CS6 but made the contact sheet be included in the default instal. I tried copying over picture package layout from CS5 optional plugins but that doesn't work, CS6 will not even recognize it. The only thing I can find is to create a picture package as a smart object and my goodness that only works as it said if you shoot the right ratio. Maybe if enough photographers protest as they did when Cs5 came out without it then Adobe may offer it as an optional plugin again.
Rayk
Gallery: 271 photos
Jun 03, 2012 06:32 as a reply to  @ Shooting's post |  #4
Try here http://download.adobe.​com …Win_Optional_Pl​ug-Ins.zip (external link)
Regards Ray
LRPS - Licentiateship of The Royal Photographic Society- CPAGB - HON CPE - ACA - Adobe Certified Associate
www.rakphotographic.co​m (external link)
Follow me on Facebook (external link)
Shooting
Jun 03, 2012 16:50 |  #5
Thanks..but those are the optional plugins for CS5. CS6 is not backwards compatible to those optional plugins so they will not work, already tried.
Shooting
Jun 03, 2012 18:26 |  #6
i guess I could reinstall CS5 just for the picture package.
ssim
Joined Apr 2003
Jun 04, 2012 01:33 as a reply to  @ Shooting's post |  #7
Have you considered making your own template and if you use smart objects it makes the process very simple once you have done it once. There are plenty of tutorials online if you need help doing it.
This has to be the first release that I can recall where the filters, plugins, etc. are not backward compatible with the previous version. If enough people ask Adobe for it, I am sure that they will provide it as an optional download.
Shooting
Jun 04, 2012 20:31 |  #8
Well, I don't know how to make my own templates. Trouble is, even on a home made template, if I want 16 wallets and have a template for it I need to have 16 copies of the image cause I can only copy a file over once. I have lumapix fotofusion for my collages and their support was very helpful telling me how to make templates and to populate an image in dragging over into as many as I need in one click.
I also have CS3 running just in case so I can use the picture package feature in that.
D ­ Thompson
Jun 04, 2012 20:42 as a reply to  @ Shooting's post |  #9
You can do it with a Smart Object and Duplicate. Use Replace Contents on one and it will update the others.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
Shooting
Jun 05, 2012 09:09 |  #10
D Thompson wrote in post #14531897 (external link)
Ok great..thank you. Now I just need to get down and dirty and learn how to replicate and work with smart objects and making templates, etc. I have no earthly idea.
D ­ Thompson
Jun 05, 2012 09:35 |  #11
Shooting wrote in post #14533870 (external link)
You've got a pm.
Dennis
D ­ Thompson
Jun 05, 2012 15:03 as a reply to  @ D Thompson's post |  #12
I think I've figured out a way to do it, but need to test it out a little more and will have to rewrite it. It's a little more of a pita to set up, but once the template is created seems to work.
Dennis
D ­ Thompson
Jun 05, 2012 16:55 as a reply to  @ D Thompson's post |  #13
This should work. It creates 2-5x7's on an 10x8" sheet. Once the initial template is made, it is fairly easy to create the package with other images. It can be adapted to set up other packages as you see fit. You can download at https://docs.google.co​m …4ijTT0KJuaXUBBQ​AHyCo/edit (external link)
Let me know what you think about it.
Dennis
Shooting
Jun 06, 2012 13:26 |  #14
Looks really nice if you want to resize your images to fit the template. I'd prefer a template where I can use the magic want and "paste into" the empty square and then size as needed, not necessary to fit the template. I managed to create such a template in Lumapix's Fotofusion, just drag and drop, no resizing needed.
D ­ Thompson
Jun 06, 2012 14:22 |  #15
Shooting wrote in post #14540500 (external link)
It pretty much works that way. When you go to Edit Contents, then Place, you resize to 5x7, flatten, and save then it updates in the template. If you want wallet sized or whatever, just create another template to drop into. I guess I'm misunderstanding what you wanted, but as long as you've got a method that works then all's good.
Dennis
14,446 views & 0 likes for this thread, 6 members have posted to it.
1693 guests, 139 members online
