Finally forced myself to only shot RAW. Question: do you sharpen raw file or want until to you convert to jpig? Or do you do a little in both?
May 31, 2012 11:15 | #1 Finally forced myself to only shot RAW. Question: do you sharpen raw file or want until to you convert to jpig? Or do you do a little in both? Canon 5D3, 60D, 70-200 L f4 IS, 17-40L,16-35f4, 24-105L,100 f2.8, 85 f/1.8, 55-250 IS, 400 f/5.6, Ziess 21 2.8, canon 1.4, 430EX www.flickr.com/photos/maggiesguy
Calicajun Goldmember More info | May 31, 2012 11:44 | #2 Good question, I do both but not sure if that the best way to sharpen. Remember, Stressed spelled backward is Desserts.
DThompson Goldmember 4,058 posts Likes: 415 Joined Feb 2008 Location: Georgetown, Ky More info | May 31, 2012 11:53 | #3 I add a little capture sharpening when converting the RAW file and then do final sharpening as the last step before converting to jpeg for print/web. Dennis
EL_PIC Goldmember 2,028 posts Likes: 1 Joined Dec 2009 Location: Austin Texas - Lucca Italy More info | May 31, 2012 12:13 | #4 Permanent banIt really depends more on your workflow and or preferences. EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | May 31, 2012 12:27 | #5 I use DPP but only to transfer straight to Photoshop as a TIFF. From here I use a third party plug-in sharpener in 3 distinct stages, once as a "capture sharpen" immediately, then whatever sharpening I feel the image might need during post processing. Finally I do a "print" sharpen to suit whatever ppi LEVEL i'M using to print. Richard
tricky500 Senior Member 424 posts Joined Sep 2010 Location: Overland, MO. More info | May 31, 2012 13:54 | #6 I don't apply any sharpening in raw primarily because I sometimes do heavy retouching after opening my RAW file, I want the sharpening to affect everything in my image equally. - Paul
BufordFZ1 Senior Member 622 posts Joined Oct 2011 Location: NE GA More info | On import from the card I use AUTOTUNE. It does a little bit of everything, exposure compensation if needed, clarity, color etc. Works well for me. A2, 60D, 5DII
tonylong ...winded More info | May 31, 2012 17:42 | #8 My normal workflow is to do all my processing in Raw. I'm not a portrait or studio shooter so don't go for "advanced" Photoshop tools. I don't often do HDR or "blending" -- I prefer to get all I can out of a Raw file, and I'm lazy and like to avoid the tiffs that get generated by working files in Photoshop. From Lightroom I'll Export photos to upload to the Web using the Screen Standard sharpening and I've been happy with the results. Tony
| Latest registered member is Niagara Wedding Photographer 1340 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
