Thread started 31 May 2012 (Thursday) 14:38
Improved Post Skills using Viveza 2...and new knowledge
Nmcgrew
May 31, 2012 14:38 |  #1
No share no more
VirtualRain
May 31, 2012 18:07 |  #2
Cool! I'm sure your models are much happier with the smooth skin... your edits take a few years off :D
I just started a trial of the Nik suite as well, can you share the control points and edits you made to each for one of these shots to help me get up to speed?
Sony a7rII / 24-240 / Zeiss 25, 55, 85
Nmcgrew
May 31, 2012 21:00 |  #3
Sure. I picked a terrible image to mess with to see what I can save, so here goes.
Straight from camera.
HTTP response: 403 | MIME changed to 'text/plain'
After RAW processing.
Here are the control points I used. I picked a slightly brighter than average spot on her forehead for the face. Brightened a tad and toned structure down. That helps smooth out the face quickly without losing much detail. Face started too bright to begin with, but I will fix that later. Next I ticked a spot on the side of her chest to tone down that shadow. Same for the spot on her arm. Then her shirt ended up way too bright, so I picked that next for a control spot. Then I went after the arm and hand that was too hot. Brought brightness down and warmed it up. Also warmed up the face. Then I adjusted the background to taste.
Here is the result.
Then I used some dodge and burn to fix a few shadows and hot spots. Note: I did not go after dust spots or blemishes or that mud on her feet (she was jumping in puddles earlier). A sharpen and noise reduction run and I was done. Somewhere in there I adjust the color balance a bit. Toned the brightness down and viola.
VirtualRain
May 31, 2012 21:06 |  #4
Thanks! So the key to smoothing the skin with this plugin is scaling back the structure?
What are you doing with those four control points in the background exactly?
Nmcgrew
May 31, 2012 22:59 |  #5
There's also another step I use for smoothing...it's part of my sharpening and noise reduction technique. Uses a channel mask to keep the details from being touched by the noise reduction. I can be VERY aggressive with the noise reduction and not lose detail.
The background points, I upped the brightness and warmth just a touch...turned the structure WAY down to give me a better bokeh look and upped the saturation.
I have also added the straight out of camera to the other post...shows you how bad this was. It was while I was dialing in the off camera flash.
Here's a full side-by-side progression.
BigBadWolfie
Joined Jul 2011
May 31, 2012 23:16 as a reply to  @ Nmcgrew's post |  #6
Yep. I'm a big fan of the U-Point technology although for some things it's not as precise as using brushes. The thing to watch out for is that it's very easy to clip things when making your adjustments.
VirtualRain
Jun 01, 2012 01:23 |  #7
Nmcgrew wrote in post #14514344 (external link)
Thanks again... this channel mask business is a bit beyond my current knowledge but I'll have to look into it. In the mean-time, I'm curious what you think of Nik Dfine for noise reduction and detail retention? It seems to work like magic to me, but perhaps I don't know what I'm missing with your technique? ;)
BigBadWolfie
Joined Jul 2011
Jun 01, 2012 13:18 |  #8
VirtualRain wrote in post #14514818 (external link)
You didn't ask me, but I use Dfine and I do think it works like magic for most photos except the really noisy ones. I find it slightly conservative in its noise reduction so for noisy pictures, you might want to pay attention to where the software is sampling from. In noisy photos, you can usually set up some U-points and take some more noise out of the background if there's a face in it.
Nmcgrew
Jun 01, 2012 21:40 |  #9
Here's a new one and I will include the sharpening/noise reduction workflow. Haven't tried dfine yet because this is working for me and I have an action setup to do it. Pardon the amount of steps and pictures, I'm a process planner by trade and this is a habit.
I shot this a long time ago using a 85mm 1.8 and a 1d MKII. It was a rainy and dark day, so I brought my two YN560s, cheapie radio triggers and used a yellow gel to create my own sunlight. The cheap triggers and the YN560s meant I could put one a few yards out into the water in this shot to get the back-light and not worry about them getting wet. I wouldn't care if they did.
From RAW:
After Viveza 2. Edited like I did before. Warmed and lighten skin. Darken and add saturation and down the structure. I did cool off the water a bit too.
Then a little curves adjustment in CS5
Now I cleaned up the rain drops, the people on the other dock, the duck butt in the water behind her knees and the fly-aways as well as a bit of dust.
HTTP response: 400 | MIME changed to 'text/html'
Now, on to the sharpening. First, you go to the channels box. I like to find the one that has the most edges around the eyes while still keeping the skin clear. For me, it was the red channel.
Next, you duplicate the channel.
Make sure only the duplicated channel is selected before moving forward.
Go to filter-stylize-find edges and select that.
(DUPLICATE IMAGE)
Nmcgrew
Jun 01, 2012 21:41 |  #10
Move the sliders until the skin and sky is clear and the main details are still black.
Do a noise-despeckle and then a blur-gaussian blur.
For the blur, pick something between .5 and 2. The goal here is to make as many speckles left in the open space grey and soften the line for the selection.
After reselecting all of the color channels and making sure the duplicate channel is NOT selected, go to selection-load selection.
Make sure you invert when you pick the channel layer you just made. It will select the details and let you sharpen the details first.
It will look like this: (windows users can select ctrl H to hide the selection)
Do a unsharp mask...you can also use other sharpening tools, but this works for me.
Nmcgrew
Jun 01, 2012 21:41 |  #11
I usually pick something very gentle.
Now, select-inverse.
Now you can reduce noise.
On this image, it wasn't too bad so it's not too aggresive. On bad images I usually go as high as 9 and details down to 20.
And then a final brightness/contrast in CS5 and viola:
And now the ol' before and after side by side. May not be perfect, and it's adjusted to my taste, but I think it's not bad for a rainy dreary Washington day.
3,195 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is EBiffany
1606 guests, 98 members online
