Thread started 01 Jun 2012 (Friday) 20:46
Keeping flash attached to the camera
Andrew_WOT
Jun 01, 2012 20:46 |  #1
Is there any harm in keeping flash attached to the camera when not in use?
I was doing that with 7D, it was pretty much permanently on, and at some point embedded flash stopped retracting, the springy flash contacts got bent so I've started religiously disconnecting flash after each use but that slows me down when at the right moment I need to grab the camera, connect the flash and only then shoot.
Curtis ­ N
Master Flasher
Jun 02, 2012 00:11 |  #2
You won't hurt it.
Tiberius
Jun 02, 2012 00:19 |  #3
I'd suggest you put it away when you aren't using it, but only for the reason that you could knock the flash and damage the hotshoe.
My photography website!PHOCAL PHOTOGRAPHY (external link)
Echo63
Jun 02, 2012 20:28 |  #4
Tiberius47 wrote in post #14519331 (external link)
+1
Every 6 months or so I damage the mount on one of my 580ex2, just from always having them on the cameras
I have stopped mounting the flash all the time, and have reduced the incidence of damaged mounts
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
windpig
Chopped liver
Gallery: 6 photos
Jun 02, 2012 22:13 |  #5
What Tiberius47 says, for sure.
Go ahead, spin the wheel.
1,013 views & 0 likes for this thread
Latest registered member is Ezra Praveen
1235 guests, 250 members online
