For shooting panoramas, how many non-parallax points do you determine for your 24-105, for example?
tvphotog Cream of the Crop More info | Jun 02, 2012 13:31 | #1 For shooting panoramas, how many non-parallax points do you determine for your 24-105, for example? Jay
tonylong ...winded More info | Jun 02, 2012 23:42 | #2 I'll plead ignorance, but ask the question: do nodal points vary with the focal length? In other words, is the question about the particular lens, or should it be about the focal length used? Tony
Jun 03, 2012 06:59 | #3 tonylong wrote in post #14522949 I'll plead ignorance, but ask the question: do nodal points vary with the focal length? In other words, is the question about the particular lens, or should it be about the focal length used? Nodal points do vary with focal length. One reviewer said he uses three points on a zoom lens: the minimum and maximum zoom FL's, and one in between. I wonder, in actual practice, if anyone uses more? Jay
gjl711 Wait.. you can't unkill your own kill. 57,737 posts Likes: 4070 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jun 03, 2012 07:11 | #4 A great tutorial on how to find the no-parallax point of you camera/lens combo. Not sure why, but call me JJ.
Jun 04, 2012 09:46 | #5 tonylong wrote in post #14522949 I'll plead ignorance, but ask the question: do nodal points vary with the focal length? In other words, is the question about the particular lens, or should it be about the focal length used? tony, they vary, but not by much. here's how to find them
Eddie xpfloyd lookalike More info | Sep 16, 2012 11:30 | #6 I found this site with dimensions http://wiki.panotools.org/Entrance_Pupil_Database Leica M11 | Leica Q2 | Sony α7RV
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 16, 2012 11:50 | #7 Even a zoom lens has TWO nodal points, the front nodal point and the rear nodal point. It is the LOCATION of the nodal point which varies based upon the FL setting of the zoom lens, so it affects multi-shot composite panorama photos. The 24-105mm zoom therefore has 81 different optical node or entrance pupil locations -- you need to ask yourself is how few of these 81 different FL positions you really need to bother keeping separate track of their locations, for the purposes of panorama shooting. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Sep 16, 2012 19:06 | #8 Wilt as the zoom function of the lens is analog surly there are an infinite number of node positions. After all there is no limit to the actual focal length you can set on the lens, between the minimum and maximum values. I guess the question then becomes are you a scientist or an engineer. The scientists answer is above. For the engineer the real question is how accurately can you either measure the location of a nodal point in the real world, or how accurately can you actually measure the set focal length and other parameters necessary to calculate the position of the nodal point, and of course to then set the system up so that rotation is around that nodal point. The answers to these questions gives you the actual number of nodal point locations that you will actually need to worry about.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 16, 2012 19:12 | #9 Alan, no debate on the points you raised from me! Thinking as an engineer, the best approximation (without an EXIF reader in the field to look at the recorded FL) are the FL indicator marks on the zoom ring, so that should serve as a starting point for how many nodal locations to bother with. That's just me. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Sep 16, 2012 20:15 | #10 With today's software (CS6 or Nik) you can shoot panoramas handheld and it will merge them just fine. "If you're not having fun, your pictures will reflect that." - Joe McNally
Osiriz Senior Member 622 posts Likes: 1 Joined Jul 2012 Location: Norway More info | Oct 24, 2012 19:13 | #11 Curtis N wrote in post #15000517 With today's software (CS6 or Nik) you can shoot panoramas handheld and it will merge them just fine. I'm as persnickety as the next guy when it comes to technical details, but... really? My thoughts exactly. Just level your tripod, mount your camera with an L plate, and you are good to go.
Eddie xpfloyd lookalike More info | Oct 24, 2012 20:32 | #12 Osiriz wrote in post #15165342 My thoughts exactly. Just level your tripod, mount your camera with an L plate, and you are good to go. ![]() The nodal point precision might have been important in the past before auto stitching existed, but not any more. I couldn't care less about setting up the nodal point, because all my panoramas comes out perfect anyway. This is only applicable when there is nothing detailed or close in the foreground. Try doing a panorama inside a room in your house without setting it up nodally and you will have all sorts of issues stitching it together due to parallax Leica M11 | Leica Q2 | Sony α7RV
| Latest registered member was a spammer, and banned as such! 2130 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
