Thread started 02 Jun 2012 (Saturday) 13:44
100-400 zoom lock won't tighten.
Curtis ­ N
Master Flasher
Jun 02, 2012 13:44 |  #1
The 100-400L has a ring behind the focusing ring that can be used to lock it into a given zoom setting. Mostly it's used to keep it retracted then not in use.
Anyway, I turn the ring all the way until it stops, but the lens still zooms. If I point the camera down, it will extend under its own weight.
Is this a user-serviceable problem, or an expensive one?
Thanks.
jhayesvw
Gallery: 167 photos
Jun 02, 2012 16:55 |  #2
gotta send it in.
I doubt it will be cheap.
My Flickr (external link)
BenMont
Joined May 2012
Jun 02, 2012 17:53 as a reply to  @ jhayesvw's post |  #3
My Dad had this on his copy, and had to have it sent in to get fixed. Unfortunately I can't give you a rough price estimate as he had all sorts of other work done at the same time. The whole lot added up to several hundred (as did mine when I had it repaired - zoom ring, IS and bearings).
BenMontgomery.co.uk (external link) | Airliners.net (external link) | Flickr (external link) | My Photography Facebook Page (external link)
mike_d
Jun 02, 2012 18:38 |  #4
And you're holding the focus ring in place while you turn the locking ring?
Bear ­ Dale
"I get 'em pregnant"
Jun 02, 2012 18:54 |  #5
mike_d wrote in post #14522033 (external link)
^ this hopefully is the problem.
Cheers,
Bear Dale
Some of my photos featured on Flickr Bear Dale (external link)
Nature ­ Nut
Joined May 2012
Jun 02, 2012 19:06 |  #6
I've read this does happen to some of the 100-400 lenses. A possible cheap fix is apparently putting a clear bike patch on the 100 end to lock it closed at least. Below is discussion about your possible issue.
http://www.birdforum.n​et …e/index.php/t-190098.html (external link)
Adam - Upstate NY:
Curtis ­ N
Master Flasher
Jun 02, 2012 21:20 |  #7
Yes. It's not a new lens. I know how it's supposed to work.
Nature Nut wrote in post #14522108 (external link)
Thanks.
claybuster
Sep 12, 2012 09:43 as a reply to  @ Curtis N's post |  #8
Has anyone here tried the clear bike patch fix? If so what kind of patch did you use and where did you get them from? I don't know anything about these patches.
MY GEAR
Whatever you are, be a good one- Abraham Lincoln
timberlandlh
Joined Nov 2011
Sep 12, 2012 14:54 as a reply to  @ claybuster's post |  #9
I have a 28-300L that did the same thing. I sent it to Canon's "CPS" and for a little over $100 they fixed it. It is a black rubber seal ring that was bad on mine.
Canon S100 and Canon 7D, Canon 28-300L 3.5/5.6 IS, Canon 70-200L 2.8 non IS, Canon 10-22 I'll give it a lil "l", Canon 50 1.8, LEE 10X Filter, Benro Travel Angel A-169....REI back pack, hiking boots and a photogenic black labrador
Eagle
Gallery: 62 photos
Sep 25, 2012 21:46 as a reply to  @ timberlandlh's post |  #10
Curtis, did you have any luck using any kind of tape?
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
7,109 views & 0 likes for this thread, 9 members have posted to it.
1545 guests, 135 members online
