Thread started 02 Jun 2012 (Saturday) 19:34
T2I and a Nifty Fifty
Chopper ­ Al
Jun 02, 2012 19:34 |  #1
Weather permitting, I am hoping to go up to the lake next weekend and would like to take some sunset and star pictures.
For the star pictures, I plan on using my Nifty Fifty and T2i. I heard that F2 to F3 is sharper than 1.8, so will give that a try. I also plan to go between 20 and 25 seconds for the exposure. The camera will be tethered to my laptop.
Does anyone know if I will start getting star trails at that time or should I shorten the time up a bit? Also, should I be taking multiple shots and stacking them later? I want to capture the Milky Way over the lake at night.
Thanks in advance...
Al
the ­ jimmy
Jun 03, 2012 08:15 |  #2
Chopper Al wrote in post #14522177 (external link)
Al
In this thread, see post #21 for a guide on exposure times vs star trailing.
archer1960
Gallery: 6 photos
Jun 03, 2012 11:28 |  #3
In short, that's probably too long for that focal length on a crop camera. 6 to 8 sec is more likely to work, depending on just how much elongation you consider "good enough". Do you have the kit 18-55? If you can drop to 18mm, you should be able to get 20 to 30 sec without trailing.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
Chopper ­ Al
Jun 03, 2012 15:17 |  #4
Thanks everyone.
archer1960 wrote in post #14524560 (external link)
What would be more likely to give a better picture? A 50mm at 6 seconds or 18mm at 20 seconds?
archer1960
Gallery: 6 photos
Jun 03, 2012 15:46 |  #5
Chopper Al wrote in post #14525409 (external link)
Thanks everyone.
Define "better"? Unless your 50 is one of the high-end 50's (1.2 or 1.4), you probably won't see much difference in sharpness between the 18-55 and a standard 50. However, being able to do longer exposures with the wider lens means you'll get much brighter exposures without having to stack individual images or crank the ISO way up. If you're shooting the Milky Way, 50 is too long anyway; you need a much wider FOV for the best composition. In fact, I find 18mm to be rather narrow on a crop; my best Milky Way shots have come with my Tokina 11-16.
Since you're shooting relatively short exposures any way, try them both lenses at various exposure lengths and see what you get, and which ones you like better.
Chopper ­ Al
Jun 04, 2012 11:16 |  #6
I guess by better I meant brighter and more stars. Sharpness and clarity is definitely a factor as well. I can't afford a proper wide angle like the Tokina that was mentioned.
Sounds like your idea of shooting with both would be the best way to go. Also, I looked at Stellarium and it looks like the Milky is still close to the horizon this time of year. So, I will practice and see what I get this weekend and get ready for when it is higher in the sky later in the summer.
Al
2,733 views & 0 likes for this thread, 3 members have posted to it.
921 guests, 108 members online
