Thread started 05 Jun 2012 (Tuesday) 09:47
Wide angle lenses and extenders ...
pixel_junkie
Jun 05, 2012 09:47 |  #1
Do any of you use your wider lenses with extenders? I always though extenders are for longer focal lengths but I recently saw in a video a photographer was using a 24TSE with an extender. Thought it was a great idea. Certainly much cheaper to go that route than to get a bunch closely FL spaced primes.
Website (external link) | Blog (external link)
5W0L3
Joined Mar 2012
Jun 05, 2012 09:52 |  #2
Doesn't using extenders mean you lose light?.. i.e. you cant use your primes @ their widest aperture?.. that to me would be one of the reasons why people don't use it on primes.
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
Cesium
Jun 05, 2012 09:55 |  #3
Kenko 2x + 35L. The result?.... not great.
IMAGE: http://i64.photobucket.com/albums/h163/newtheory/b579790b.jpg
IMAGE: http://i64.photobucket.com/albums/h163/newtheory/f1d5f518.jpg
pixel_junkie
Jun 05, 2012 10:02 as a reply to  @ Cesium's post |  #4
^ I mean the tele extenders, like the 1.4X and 2X
andyjensen
Jun 07, 2012 05:10 |  #5
That's what Cesium did there. Extenders are meant for tele lenses where you need a fairly large jump in FL to make a big difference. At wider angles a relatively small change in FL is more noticeable. Going from, say, 35mm to 50mm (1.4x) or to 70mm (2x) is a decent jump. I think you're better served to have a pair (or set) of primes and keep the IQ, or just get a zoom.
Besides, Canon's extenders won't work on anything shorter than the 135L (with the exception of the 70-200 zooms), so you're left with third party extenders which are, well, generally not that great.
I can see this working in a niche use (eg with a TS lens as you mentioned) where it would be prohibitively expensive to get multiple FLs. Also, videographers sometimes do strange things. :p
Some clicking occurred, a few lenses were involved, that's about all I know ...
Wilt
Jun 07, 2012 17:32 |  #6
Folks have long used telextenders to alter the effective FL of optics that are ordinarily 'normal' optical designs, in addition to using them with long FL lenses known as 'telephoto'. In more recent years folks have resorted to using them with wide angle shift lenses, to make them 'less wide angle'. I don't know optically how unwise that last usage is, since I haven't seen objective measurements of what happens to MTF resolution at the center and at the edge of the frame, in doing so.
The thing to keep in mind is that telextenders are
  • primarily designed to work with optical designs known as 'telephoto', where the rear nodal distance < FL.
  • 'Normal' lenses have the nodal distance ≈ FL;
  • wide angle lenses for SLRs are typically 'retrofocus' designs which have nodal distance > FL in order to clear the reflex mirror.
The fact that Canon telextenders have a front element that protrudes in front of the location of the forward lens mount is an indirect clue about the fact that they are designed for the 'telephoto' lens that has room for that front element. The fact that the 17mm TSE has room for a Canon telextender as well, is simply an 'accident' of designing a lens that can shift in two directions without hitting the lens mount on the body.
M_Six
Gallery: 68 photos
Jun 07, 2012 17:37 as a reply to  @ Wilt's post |  #7
I've tried my Kenko 2x extender on my Roki 35mm and got results similar to Cesium's. Sort of foggy. Almost like some moisture got in the way, even though none did.
Mark J.
Gear
NewEnglandPhotographer
Jun 07, 2012 17:38 |  #8
a good rule I go by.. if the lens is white, it will accept a TC. If the lens is black, it won't. (canon only obviously)
Canon 7D | 70-200mm f2.8is II L | 24-70mm f2.8 L | 50mm f1.8 | 28mm f1.8 | Canon 1.4x TC II | 580EX II
Shadowblade
Gallery: 26 photos
Jun 09, 2012 16:03 |  #9
They work beautifully on my TS-E 17L and TS-E 24L. Essentially, they give me a whole stack of extra primes that otherwise wouldn't exist.
jimewall
Jun 09, 2012 18:05 |  #10
ewheeler20 wrote in post #14546784 (external link)
All whites and of current (black) lenses the 135L, 180mm macro, 200mm f2.8 L - I think. Is this correct?
Thanks for Reading & Good Luck - Jim
GEAR
bob_r
Gallery: 24 photos
Jun 09, 2012 18:16 |  #11
jimewall wrote in post #14556047 (external link)
I don't believe the 70-300L will work with a Canon TC and it's white.
Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Sigma 150 macro, 1.4X, 2X, Quantaray 2X, Kenko closeup tubes, Yongnuo YN685(3), Yongnuo YN-622C-TX. Lots of studio stuff.
** Image Editing OK **
Jun 09, 2012 18:53 |  #12
crap.. ok my white vs black rule doesn't work, lol. How about this: All MY white lenses work with the TC. All MY black lenses dont. :)
1Tanker
Jun 09, 2012 23:53 |  #13
ewheeler20 wrote in post #14556193 (external link)
And again.. this is only with Canon TCs. I use my Sigma 1.4x TC all the time on my 100/2.8 USM macro(black and under 135mm), with excellent results. ;)
Kel
Gear
Wilt
Jun 10, 2012 11:58 |  #14
pixel_junkie wrote in post #14534027 (external link)
Back to the point that I made earlier, about teleconvertors being designed for use with 'telephoto' optical design lenses...
On Kenko's own website, they specifically point out that their teleconvertors,
"The PRO 300 family are designed specifically to be used with prime telephoto lenses of 100mm or above, such as 300 mm f/2.8 lenses, and work best with telephoto lenses of 200mm to 500mm. The PRO 300 can be used with telephoto zoom lenses as well as prime lenses. However, Kenko does not recommend them for zoom lenses that have a range starting under 50 mm."
Yeoer
Jun 10, 2012 15:28 |  #15
My Kenko pro 300 lets me use my Sigma 10-20 on my 5D2... work really quite well.
https://photography-on-the.net/forum/showthre​ad.php?t=909337
Canon 5D MarkII, 40D, 350D, EOS100, G10. Canon 24-105 F4 L, 85mm, 400mm F5.6, 50mm F1.8, 18-55mm, Sigma 10-20, 100-300mm, Canon 28-105 F3.5-F4.5, Kenko x1.4, Tubes and a bunch of Elinchrom Lights, flashes, reflectors and triggers.
6,476 views & 0 likes for this thread, 12 members have posted to it.
1122 guests, 112 members online
