As the title says from MSA BEC from Brands Hatch. Comments and constructive critisim are welcomed (as it will help me learn)
1.
2.
3.
4.
5.
6.
7.
8.
Full set here: http://www.flickr.com …2/sets/72157630065949770/
Stevie
StevieBorowik Senior Member 314 posts Likes: 93 Joined Apr 2012 Location: UK More info | Jun 06, 2012 10:13 | #1 As the title says from MSA BEC from Brands Hatch. Comments and constructive critisim are welcomed (as it will help me learn) 2. 3. 4. 5. 6. 7. 8. Full set here: http://www.flickr.com …2/sets/72157630065949770/ Thanks Stevie My gear: Canon 5D mkIII, Canon 7D mkII, Canon 1.4x mkIII Teleconverter, Canon EF 24-70mm f/2.8 L, Canon EF 135mm f/2 L, Sigma 120-300mm f/2.8, Sigma 50mm f/1.4 Art
chrispons Goldmember 2,368 posts Joined Feb 2008 Location: worcester More info | Jun 06, 2012 11:10 | #2 Quite like 2 ,but the rest look a bit boring,though well taken. Pons
Jun 06, 2012 11:55 | #3 chrispons wrote in post #14539762 Quite like 2 ,but the rest look a bit boring,though well taken. What can i do to make my shot more intresting then?? My gear: Canon 5D mkIII, Canon 7D mkII, Canon 1.4x mkIII Teleconverter, Canon EF 24-70mm f/2.8 L, Canon EF 135mm f/2 L, Sigma 120-300mm f/2.8, Sigma 50mm f/1.4 Art
thampel09 Member 128 posts Joined Nov 2008 Location: South Jersey More info | Jun 06, 2012 18:48 | #4 These are a good set of pictures. And to touch on the boring aspect, Maybe if you were a little lower and more level while shooting the cars (i'm guessing you were in grand stands) also maybe try to get a little more motion blur by dropping the shutter speed a step or two. -Tom
DegasGoneDigital Goldmember 2,037 posts Likes: 33 Joined Apr 2006 Location: Eastern Virginia More info | Jun 06, 2012 19:40 | #5 Excellent shot.. -Sam.
Jun 07, 2012 01:58 | #6 thampel09 wrote in post #14541929 These are a good set of pictures. And to touch on the boring aspect, Maybe if you were a little lower and more level while shooting the cars (i'm guessing you were in grand stands) also maybe try to get a little more motion blur by dropping the shutter speed a step or two. I didnt go into the stand at all its just the lay of the land at brands very undulating. when you get closer to driver level you cant focus through the fence as the track is so close. I have been messing with slower shutter speeds was taking soom at 1/40th sec just the majority of the slower ones are a bit shacky :-S so I think ill need my monopod next time. Thanks for the feedback though. My gear: Canon 5D mkIII, Canon 7D mkII, Canon 1.4x mkIII Teleconverter, Canon EF 24-70mm f/2.8 L, Canon EF 135mm f/2 L, Sigma 120-300mm f/2.8, Sigma 50mm f/1.4 Art
thampel09 Member 128 posts Joined Nov 2008 Location: South Jersey More info | Jun 07, 2012 07:23 | #7 Stevie Borowik wrote in post #14543501 I didnt go into the stand at all its just the lay of the land at brands very undulating. when you get closer to driver level you cant focus through the fence as the track is so close. I have been messing with slower shutter speeds was taking soom at 1/40th sec just the majority of the slower ones are a bit shacky :-S so I think ill need my monopod next time. Thanks for the feedback though. Stevie Gotcha, yeah every track varies from one to another. I was looking at your complete set on your Flickr and you have some other really good ones on there. A few you could possibly just use a little more cropping on than others but you have a bunch of solid shots there. But don't get discouraged if you have a ton of blurry pictures cause I have a season pass to my local track (new jersey motorsports park) and after a day of shorting I may only Come home with 5 good track shots. Also a monopod may not be a bad idea. I have used one a number of times and the results vary depending on location but it could help! Good luck! -Tom
Jun 07, 2012 12:39 | #8 thampel09 wrote in post #14544046 Gotcha, yeah every track varies from one to another. I was looking at your complete set on your Flickr and you have some other really good ones on there. A few you could possibly just use a little more cropping on than others but you have a bunch of solid shots there. But don't get discouraged if you have a ton of blurry pictures cause I have a season pass to my local track (new jersey motorsports park) and after a day of shorting I may only Come home with 5 good track shots. Also a monopod may not be a bad idea. I have used one a number of times and the results vary depending on location but it could help! Good luck! I seem to get about 10% out of all the shots I take that are worth keeping. The editing is something im not too sure about so could always learn My gear: Canon 5D mkIII, Canon 7D mkII, Canon 1.4x mkIII Teleconverter, Canon EF 24-70mm f/2.8 L, Canon EF 135mm f/2 L, Sigma 120-300mm f/2.8, Sigma 50mm f/1.4 Art
| Latest registered member is finnianmarlowe 1329 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
