Hey guys. After a few external HD failures and some network & LR incompatibilities, my partner and I are left scratching our heads in regards to a working/backup storage solution.
At the moment, we have a few 500GB-2TB external HDs as well as a brand new Lacie 2Big Network 2 Raid server.
Initially, we had planned to use the Lacie as a working backup but realized it wasn't that fast and LR doesn't like it when you store catalogs on a network.
A working storage solution would be easy to set up if it were just one photographer but having two people involved in post makes things a lot more complicated. We're considering returning the server and starting fresh. If we can keep it, that would make things convenient.
Do you guys have any suggestions for a multi-photographer storage system? Would it be smart to have an external HD to work off of and then back that HD up using the Lacie server? (This would require us to pass the HD around leaving one of us unable to edit at the same time since we share catalogs and don't want to mix up our working files.)
Advice would be greatly appreciated! We just want a simple working solution with safe backups...
