I got given this camera to have a look at to see if I could fix it. Here is the problem;
Whenever the main battery is removed and plugged back in, the camera will not turn on at all. As if no power is available what so ever.
The only way to get it to turn back on is to do a hard reset, remove all batteries, CF, lens and wait 20 mins. Plug everything back in and voila, the camera is back working.
As soon as you remove the battery, the camera requires a hard reset again.
Has anybody come across this before, is it a problem with the power board? Thanks.
