I'm posting this here, because I think it's the computer more than Lightroom.
I have a computer that was given to me a while back, when the original owner upgraded to something else. He had the computer built for him and when it stopped working, he upgraded. I found the problem to be the video card and replaced it and have been using it ever since.
LR runs fine and fast, as long as I'm doing no real processing. However, if I start getting into skin and hair masking and whatnot, it starts to bog down. Opening the task manager will reveal that only about 45% of ram is in use, but LR is using 100% of the processor. This happens, also, when simply bringing a photo up that has had skin and hair masking/processing. When I say it slows down, I mean it will be minutes before a change is seen, when moving the sliders. Or, if opening LR, and that image was the last image displayed (so it is what comes up when you open it), LR will open quickly, show the image in the library, and show the "loading" message for quite a few minutes before I am able to do anything.
LR 3.6 is installed to C:. My catalog is installed to D:. The Camera Raw Cache is set for 50GB is located on D:. I have tried it on C:, as well, with no change.
The Windows paging file has been tried on C: and D:, both system managed size, with no change.
Just for giggles, I went into the nvidia control panel and made sure that the GTS 450 was set to be used by LR (I think LR is a CUDA compatible application? It didn't say it wasn't.)
MSI Motherboard MS-7390 (K9N SLI-F V.1)
AMD Athlon 64 X2 Dual Core 6000+ 3.01 GHz
8Gb DDR2 PC2-6400 RAM
nvidia GTS 450 1GB video card
C: is a 160GB 7200rpm SATA drive
D: is a 500GB 7200rpm SATA drive
G: is a 500GB GoFlex drive used for backup
Windows 7 Home 64 bit Service Pack 1
I'm not sure what I'm looking for here, other than just confirmation that it's probably the processor that is the bottle neck in the problem I am describing. But, maybe it's something with my setup for LR.
Thanks for your time.
