POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 08 Jun 2012 (Friday) 16:57
Canon 17-55 hood question
mosabi
Jun 08, 2012 16:57 |  #1
Is there a real reason to get the factory canon hood instead of an after market?
The only big difference I see is the price.
Factory:
http://www.cameta.com …7-55mm-f-2-8-IS-19914.cfm (external link)
After Market:
http://www.cameta.com …55mm-f-2-8-EF-S-25506.cfm (external link)
Website:
www.nickluchau.zenfoli​o.com (external link)
40Dx2 gripped | 17-55 f/2.8 | 50 f/1.8 mk1 | 430ex II
BTNorris
Jun 08, 2012 18:28 |  #2
How about for $11...
http://www.amazon.com …keywords=hood+c​anon+17-55 (external link)
I bought an aftermarket hood - it feels a little cheap but sturdy enough. I haven't noticed any problems not having the flocking inside the hood.
7D, 17-55, 50 1.4, 70-200, 10-22, Kenko Tubes, OPTIX xr, Einstein
Judsonzhao
Joined Feb 2012
Jun 08, 2012 19:13 |  #3
Go to eaby try some Chinese ones, even better than opteka..
Fly me away.
klr.b
Jun 08, 2012 20:00 |  #4
Those third party hoods usually lack the flocking on the inside. If you like to DIY, you could replicate it yourself. It's hard to say if they are truly identical in make up. The OEM hoods will absorb the impact if you bump into something. The third party hoods don't always fit as well, and I haven't really seen someone praise their third party hood for saving their lens.
So flare prevention can be pretty close. Actual protection is up in the air. I bought OEM hoods because I didn't want to risk it. The Canon hoods are proven, and saving $30 isn't worth the risk on >$1000 lenses. On a $100 kit lens, I wouldn't mind the risk of a cheap hood, though.
gordon
Gear and Feedback
Grand_gator
Joined Mar 2011
Jun 08, 2012 20:14 |  #5
I go the OEM myself and I agree with Gordon on the bumping protection and fit. On the other hand, they scratch and get fingerprints fairly easily, so it is your call. But in a 1K lens I decided to go original.
5Diii / 70-200 L IS II / 100-400 L IS II / 24-105 L IS / 100mm 2.8 L Macro IS / Σ 35mm 1.4 Art / Σ 85mm 1.4 Art / EF-S 10-22mm / EF-S 17-55mm IS / EF 70-300mm IS / 50mm 1.8 II / 600 EX RT + 430 EX II
Tom_D
Jun 08, 2012 22:17 |  #6
Another vote for eBay. I think mine was about $5.00 and was mailed from Hong Kong. I have been happy with it but have banged it up quite a bit and am about ready to order another.
Gallery (external link)
7DMkII, 40D, 17-55, 70-200 f/2.8 IS and more...
More Wag, Less Bark
mosabi
Jun 09, 2012 06:07 |  #7
Thanks for the replies on this. What is the true benefit of the felt they put inside the hood?
Checking over amazon I found the OEM hood for $34. I can't believe they can sell this thing elsewhere for $50 - $60. $34 is outrageous as well but I may ask for it for fathers day :)
Website:
lilkngster
Jun 09, 2012 08:30 |  #8
i have both, originally bought a aftermarket and later got a used OEM.
I use the OEM and retired the 3rd party because 1) better reverse fitting, 2) much stronger plastic, and 3) flocking. I did not notice any real difference with and without the felt, but I never shoot into or towards the sun.
I can imagine that the flcoking might decrease the prescence of scattered and off angled photons hitting the front element, but the relative improvement in terms of decreased flare is probably nothing compared to the improvement with and without hood.
6dII/1dIII|Bronica Sq-Ai/EOS 3/A1
marcosv
Jun 09, 2012 09:30 |  #9
I bought two 3rd party hoods and regretted it. The first one was such a poor fit, that it wouldn't attach without a lot of force. It also vignetted. The second one (more expensive) seemed to be just fine, except it started to warp a bit (not very good plastic) and eventually it too vignetted.
I ended up buying the Canon hood and been done with it.
EOS-M | 40D | 5DII | 5DIII | EF-M 22 | EF-M 18-55 | 10-22 | 17-55 | 17-40L | 24-70L mk II | 24-105L | 70-200/2.8L IS mk II| 35L | 85L II |35/2 | 40/2.8 pancake | 50/1.8 | 50/1.4 | 100/2 | Rokinon 14/2.8 | 90 EX | 270 EX II | 580 EXII | 600 EX-RT
Preeb
Gallery: 151 photos
Joined Sep 2011
Jun 09, 2012 10:30 |  #10
Grand_gator wrote in post #14552752 (external link)
Same here. It's not that expensive when you consider what you're buying it to protect. The flocking prevents any possible shine or reflection off the plastic inner surface.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
number ­ six
fully entitled to be jealous
Jun 09, 2012 14:38 |  #11
mosabi wrote in post #14554014 (external link)
I'm not sure there is an advantage. I have a Canon hood (with teddy bear fur) for my 70-200 and a cheap aftermarket hood (inside painted flat black) for my 17-55. The reflectance seems to be about the same.
A disadvantage of the furry hood is it picks up dust...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
RPCrowe
Joined Nov 2005
Jun 09, 2012 20:59 as a reply to  @ number six's post |  #12
I have two Chinese made, eBay hoods (one for a back up). The bayonet models work great.
However, I once purchased an Opteka, screw mount, butterfly, lens hood and it would not screw into my filter threads.
2,929 views & 0 likes for this thread, 11 members have posted to it.
3202 guests, 149 members online
