Thread started 08 Jun 2012 (Friday) 20:16
Filters and ultra wide lenses
Diver-Down
Jun 08, 2012 20:16 |  #1
I shoot allot of waterfalls and I'm often faced with tight quarters and big falls and my 17-50mm just isn't wide enough at times. So I've been thinking about one of the ultra wides, 10-22mm or so. Now I understand that these should only be used with slim filters to avoid vignetting but I assume that I'm limited to one filter ? I usually start with a CPL but then often end up stacking a ND or two on top. I haven't noticed any vignetting at 17mm when stacking regular filters so I'm wondering where this really becomes critical ? I don't think I would necessarily need 10-12mm but probably use the 12-17mm range the most.
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jun 09, 2012 18:34 |  #2
Diver-Down wrote in post #14552762 (external link)
First, as a general rule you shouldn't be using CPL filters on UWA lenses. Shots of blue sky wider than 20mm or so will usually show strong color variations from one end of the photo to the other with a CPL attached. Second, I personally never stack filters and find it hard to believe that you can place 2 ND filters in front of a CPL and not get noticeable vignetting.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
ZoneV
Jun 09, 2012 19:11 |  #3
On my Samyang 14mm f/2.8 and other lenses I use filter in the camera mount.
Nont on the lens back itself, there is no filter holder. I cut filter to the inner size of the mount. No problems up to now.
IMAGE: http://www.4photos.de/camera-diy/Einlegefilter-im-Bajonett-.jpg
It is a very unique way, but not the worst one :-)
DIY-Homepage (external link) - Image Gallery (external link) - Gear List
Hogloff
Joined Apr 2003
Jun 09, 2012 19:20 |  #4
mwsilver wrote in post #14556155 (external link)
He's shooting waterfalls so most likely he wants to saturate the foliage around the waterfall with the polarizer which works just fine with a polarizer. I shoot waterfalls quite often with a 17mm on full frame with a polarizer and have no issues at all.
sandpiper
Jun 09, 2012 19:28 |  #5
You are right about blue skies and CPLs on UWA lenses, but that doesn't make it a general rule that you shouldn't use them, just that you should be careful if there is a lot of sky in the shot. They are useful for a lot more than just blue skies, and in a waterfall shot with little or no sky visible they are great for taking glare off the water and foliage.
You are right though that there is no way to stack a CPL and ND filters at the short end of a 10-22mm without noticeable vignetting, although it "might" be possible towards the long end without problems.
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jun 09, 2012 19:53 |  #6
Hogloff wrote in post #14556285 (external link)
I guess I stand corrected wih regard to using CPLs and UWA lenses. I guess it depends on what you're shooting.
Mark
Diver-Down
Jun 09, 2012 20:18 as a reply to  @ mwsilver's post |  #7
I don't stack 3 very often but have done it. I was probably on the wide end but don't remember for sure. The other thing about most of the waterfalls that I shoot is that it would be pretty hard to notice vignetting unless it's really bad since the corners are almost always in the shadows or trees and rock, almost never sky. I mostly use the CPL to cut the glare on the water but it also saturates very nicely too.
Sounds like I would be pretty limited with an ultra wide though.
Hogloff
Joined Apr 2003
Jun 09, 2012 20:22 |  #8
mwsilver wrote in post #14556358 (external link)
Yep, but in general, if there is sky in your image, a polarizer could really butcher up the sky when using a wide angle. Been there, done that.
Hogloff
Joined Apr 2003
Jun 09, 2012 20:23 |  #9
Diver-Down wrote in post #14556430 (external link)
I regularly use a slim polarizer, a ND filter and I'll hand hold a GND filter with a 24mm on a full frame without vignetting.
ZeroSkylineX
Joined Jun 2012
Jun 10, 2012 00:23 as a reply to  @ Hogloff's post |  #10
Anyone have filter recommendations? Specifically for my Sigma 10-20mm. (77mm)
Canon Rebel 600D/T3i | 580EX II
Sigma EX 10-20mm f/3.5| EX 17-50mm f/2.8 OS| EX 50mm f/1.4| EX 70-200mm f/2.8 II
500px (external link)
Sirrith
Gallery: 50 photos
Joined Nov 2010
Jun 10, 2012 04:02 |  #11
You can stack CPLs and NDs using the Lee kit, which accepts either a very expensive 105mm circular CPL or the Lee square CPL which is also quite expensive. But doing it that way will enable you to stack without any vignetting, and is far more flexible than stacking screw-ins.
-Tom
hollis_f
Jun 10, 2012 05:35 |  #12
Hogloff wrote in post #14556445 (external link)
Could, not would. As Sandpiper says, it's not a general rule. Knowing how a CPL works will help a lot in predicting whether or not it will be helpful or harmful in any particular situation.
Here's an image that shows how the degree of polarization changes with the sun behind one's back. If one were to shoot in the same direction, landscape orientation, then there would be no problem with uneven CPL effects.
IMAGE: http://www.frankhollis.com/temp/CPL%20North_20120326_001.jpg
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
3,657 views & 0 likes for this thread, 8 members have posted to it.
1332 guests, 137 members online
