That's the way it appears, and I am shocked that even on this model only the center point is set to actually use a lens that is faster than 2.8. So with all the 85mm 1.8 portraits lenses out there, the 100mm F2, the 501.4 and 1.8, all the great, fast lenses out there.my Sigma 30 1,4, Canon still does not not a way to use the outer focus points for faster lenses with the same precision that they can use the center point?
Here is the quote from a review about the 7D, and it is the same with the 50D and 60D.
"Each and every point, including those located farthest from the center, is a standard-precision cross-type sensor, which can be used with any lens (or lens plus extender combination) with effective maximum apertures of f/5.6 or faster. Like the EOS 60D and 50D before that, the center AF point also has a separate, diagonal pair of high-precision line sensors, which provide even greater precision; these are automatically used with lenses f/2.8 or faster."
This clearly states that even on the 7D the outer points are NOT THE EQUIVALENT of the center point, and this sux because in portraiture I was hoping to upgrade to a 7D specifically so that i could use my 100mm F2 and my Sigma 30 1.4 with the outer focus points so that I would not have to focus and recompose.
So do you 7D owners out there use your outer focus points with faster than 2.8 lenses, and if it works just fine, why would any review or even Canon ever mention a difference in the center and outer points, since the difference matters not?
I'm saying that there must be a difference or they wouldn't make sure and spell out that the center point is set to function optimally with faster than 2.8 lenses and that the outer points are NOT THIS TYPE OF FOCUS POINT.
I am hoping you 7D owners can say "Hey, no problem, I focus with my fast lenses using the outer points and see not a bit of difference with them compared to using the center point, why, i don't even know why Canon would mention any difference because I have had zero difference with the center one compared to the outer ones"
