FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 10 Jun 2012 (Sunday) 11:33
Need some settings suggestions for a night shoot
GTT
Joined Dec 2011
Jun 10, 2012 11:33 |  #1
Using an S95
No experience with night shots.
Here is the deal.
My wife is an Artist and was selected to have images of her art shown with others and they are to be projected onto a wall of water starting at dusk. I have no idea what the lighting conditions will be like in this park tonight. Probably will start of with enough light at beginning and then as dusk is over be quite dark.
Not sure about low light mode but as it is all auto with a very high ISO doubt it would be correct to use.
Not sure if the water will come into play and show a blur under slow shutter speed.
Any suggestions for settings as a starting point?
etaf
Jun 10, 2012 11:59 |  #2
congratulations - I bet that will look spectacular
to your question , this at least shows a wall of water and maybe something to try and practice without the flash use
http://www.diyphotogra​phy.net …-through-a-water-wall-but (external link)
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
GTT
Joined Dec 2011
Jun 10, 2012 12:05 |  #3
etaf wrote in post #14558794 (external link)
Thanks for that link, but with 8 hours until showtime it will not help.
Some of those photos are very creative and worth a look.
etaf
Jun 10, 2012 12:18 |  #4
are you going to be able to use a tripod at all - ?
can you set auto ISO on the camera at all and you wont need to much of a aperture as its a flatish subject
can you shoot in raw so you have a chance for some post processing ?
how far away will you be and what size is the wall ?
GTT
Joined Dec 2011
Jun 10, 2012 12:33 |  #5
etaf wrote in post #14558860 (external link)
Tripod yes but if I want to get close I might have to hand shoot.
ISO can be set to auto or fixed 80-3200 I believe
I usually shoot in both raw and jpg, raw not available on full auto.
Have no idea how far away we will be but hopefully it will be like 50 ft or so at most.
Don't know the exact size but it is quite large based on the limited info provided.
Sorry the info is limited but it is a first event and those running it haven't provided a great deal of info.
etaf
Jun 10, 2012 12:56 |  #6
i would first start at the highest ISO, on the body where you know the noise would be acceptable and then see what range of shutter speed i get at a reasonable aperture for a good DoF
and then play all three and just take lots of shots - if you have high speed drive speed , and do you have bracketing available - that may be worth a try
how long is it running for
hnikesch
Gallery: 24 photos
Jun 10, 2012 17:37 |  #7
You say the images will be projected outdoors at night on falling water, the images should look like they were projected on a screen, I have seen this in Vegas. If you under expose about 2stops you should be able to hand hold and get both the projected image and the surrounding area. Do a little trial and error to fine tune the exposure. I got some good shots using my SD 900 hand held at about ISO 500. I am sure the 95 will do better
Hans
Hans
etaf
Jun 11, 2012 03:42 |  #8
post a few images , looking forward to seeing the results
GTT
Joined Dec 2011
Jun 11, 2012 08:33 as a reply to  @ etaf's post |  #9
Hey everyone thanks for the help. Turned out we got thrown a curve and it was impossible with my S95 to get any decent photos. The site for the water screen was placed across a river about 80 yards away and being only 30ft wide and 15ft high was hard enough to see with the naked eye. We had understand it was going to be set up on a amphitheater next to the river and only about 50-100 ft from viewing area.
I took a picture of the screen in daylight using my cameras full digital zoom 15x so people can see what the screen was. When seen at night had we been closer I believe the images would not have been as sharp as I first thought because even from a distance I could see fine vertical lines in the waterflow.
Night wasn't a total bust as it was a hot day and there was food, music and friends to visit with plus the shows producers learned a valuable lesson for next time.
http://www.flickr.com/​photos/22760340@N07/ (external link)
Content warning: script
1,285 views & 0 likes for this thread
Latest registered member is marcuse2004
1714 guests, 273 members online
