Thread started 11 Jun 2012 (Monday) 09:55
Question about 50mm f1.8
chongkiat
Joined Apr 2012
Jun 11, 2012 09:55 |  #1
Okey guys , after owning the 50mm f1.8 for quite some time , today suddenly give a test to my lovely Tamron 17-50mm f2.8, 85mm f1.8 & 50mm f1.8 AF test
When doing the test , i mount the my 60D on tripod to avoid any hand shake , so after done the tamron and the 85mm f1.8 out , i found this two lens is really great in focus even at wide open , happy with this 2 lens
So when i pick up my 50mm f1.8 to doing the test , until today only i found that , IF we focus on the same thing , keep on repeating half-press the shutter , the focus ring will keep on turning Clockwise and counter-clock wise by ABIT......(mean if u shooting the same image , it will turn 2 different DOF , see the picture below)
Mean
When half press > It will Focus > Release Shutter and Half Press again(if u focus on the same thing , the focus ring SUPPOSE not MOVE anymore, BUT the focus ring will turn Clockwise Once , if u repeat "release and PRESS shutter Half way down" , the focus ring will turn Counter-Clockwise)
Here is the picture sample, 60D mount on tripod , FOCUS on the same thing which is the "AMD 64 Atholon"
First Picture !!
IMG_0824 (external link) by Lau test (external link), on Flickr
Second picture , On the same spot , focus on the same thing
IMG_0825 (external link) by Lau test (external link), on Flickr
Crop out to see the DOF clearly
problem (external link) by Lau test (external link), on Flickr
See the different?? my 60D is mount on the tripod , focus on the "AMD 64 Atholon" Logo , i would like to know ur 50mm f1.8 got such problem or not?
Please help me check out guys !!!
Canon 60D Gripped | Canon 17-55mm f2.8 IS USM | Canon 85mm f1.8 USM | Canon 580exII
My Flickr (external link)
GregoryF
Jun 11, 2012 10:24 |  #2
I have always found the focus of the 50mm 1.8 II eratic like you are experiencing (3 copies). I did pick up a version mk1 of the 50mm 1.8 at it is much more consistent.
6D, 5D, 7D, 50D, 40D, Xsi, PENTAX mx-1, Sony a6000, Sony a3000 too many lenses, flashes and aux. gear to list!:cool:
A simple hobby gone horribily wrong
chongkiat
Joined Apr 2012
Jun 11, 2012 10:34 |  #3
so , will the 50mm f1.4 solve my problem??? I got no problem on tamron 17-50mm f2.8 and canon 85mm f1.8 , the focus ring won't MOVE if i focus on the same subject , but the 50mm will focusing even focus the same subject :confused::confused:
Virto
Joined Nov 2010
Jun 11, 2012 10:51 |  #4
It's the camera picking up the differences in contrast. It's not always a sure thing, especially if you're close to the MFD of the lens. Back the tripod up another 2-3 feet and try again, and let us know what aperture you're shooting at. At 1.8, shallow dof can make it seem like a lens missed focus.
Don't forget that the focus sensor is actually bigger than the little box you see in the viewfinder. The camera will look for the most obvious difference in contrast in that area, and focus on it, and it might not be the logo you're shooting.
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
chongkiat
Joined Apr 2012
Jun 11, 2012 11:20 |  #5
Virto wrote in post #14562883 (external link)
The problem is it only happen on 50mm f1.8, the 85mm f1.8 and tamron 17-50mm got no this problem, i focus on the same subject it suppose no more hunting if u refocus on the same subject, but the 50mm focus ring just sill move around if u half press and re-half press
saintz
Joined Mar 2012
Jun 11, 2012 15:48 |  #6
I had stopped using the 50 1.8 because of similar focus issues. In lower light the focus is just not reliable. Sometimes it won't grab at all.
The 50 1.4 is much better. The only time I've had issues is when very close to MFD on the 50 1.4 (which is really user error).
Sony A6000 | 18-55 | 16-50 | 50 f1.8
DC ­ Fan
Jun 11, 2012 18:27 as a reply to  @ saintz's post |  #7
An alternative way to check the focus response of a Canon 50mm f/1.8 II lens is to use it to gather images of people. That was done in these examples.
In these situations, there were no focus problems, even though the subjects were moving. Perhaps the camera handles moving subjects differently than static subjects in a single plane..
chongkiat
Joined Apr 2012
Jun 11, 2012 19:25 |  #8
I just feel that sometime i can focus accurately but sometime not, look like i need to stop down to at least f3.5 to get accurate sharp image =.=, really no point to keep this 50mm f1.8 if need to stop down since my tamron at 50mm f2.8 also able to give the sharpness
kay188
Jun 11, 2012 22:35 |  #9
Known issue about this lens since time. It's because of it's cheap built and it's AF motor. It's not as accurate as more expensive lenses.
The reason why you get sharper images having it stopped down because your DoF increases allowing focus error to hide.
Ricoh GRD4 | Canon 1Ds, 1D, 1D2, 1D2n| Canon XTi | Tokina 11-16 F/2.8 | Canon 16-35L I | Canon 24 F/2.8 | Canon 35 F/2 | Canon 50 F/1.8 I | Canon 135L | Sigma 24-70 EX DG Macro | Sigma 70-200 F/2.8 APO EX DG | Sigma 30 F/1.4 |Sigma 50 F/1.4 |Sigma & Kenko 1.4x TC| Canon 580EX II | Sigma EF-500 Super | 2x Vivitar 285HV | RF-602 Triggers |
kin2son
Joined May 2011
Jun 11, 2012 22:58 |  #10
chongkiat wrote in post #14565300 (external link)
you get what you pay for. What do you expect from an el cheapo $100 lens???
The 50 1.8 focus has always been slow, erratic and noisy.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
chongkiat
Joined Apr 2012
Jun 12, 2012 00:30 |  #11
kin2son wrote in post #14566187 (external link)
Did i complain it to be slow and noise??? I know i get what i paid , i just wan to confirm that izit how this 50mm f1.8 work?? Mean when u focusing on the SAME Object , the focus stil will moving even at 2nd time Focus......the focus ring suppose not to rotate anymore if the object is focus
Maybe i should take some video and upload here
kin2son
Joined May 2011
Jun 12, 2012 01:14 |  #12
chongkiat wrote in post #14566510 (external link)
I think that's normal? Because when you half press the shutter, the lens will go thru the auto focus process. Now as we all know the nifty is bad at focusing, it goes thru the AF cycle again (thus the rotation) when you half press the second time. Also because it's focusing ability is so terrible (and slow and noisy), the result will be random, sometimes it finds something to lock on, sometimes it doesn't. Despite the fact that it's on a tripod and focusing on the same thing.
The other lenses you own does the same process, the only reason you don't realize is because the AF on the other lenses are faster and quieter compared to the nifty that's all.
Hope this explains it.
tfd888
Jun 12, 2012 01:18 as a reply to  @ kin2son's post |  #13
Mine will do this time to time as well. Having used a couple copies of this lens, I personally think it's just how the lens is. This lens is not known for it's amazing AF capabilities :lol:
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website (external link) - My Blog (external link)
- My Flickr (external link)
algold
Jun 12, 2012 01:29 |  #14
erratic, inconsistent and noisy AF were the reasons why I sold my 50/1.8 II. the IQ was pretty good when it managed to focus right.
100D, 40D, 10-18 IS STM, 18-135 IS STM, Sigma 30/1.4, 40/2.8 STM, 60/2.8 macro, MP-E 65/2.8, 85/1.8, 70-200/4 L, 270EX, 430EX, MR-14ex, Metz 58 AF-1
EOS-M3 22/2, 18-55 is stm
chongkiat
Joined Apr 2012
Jun 12, 2012 02:42 |  #15
Would think to upgrade to 50mm f1.4, will the focus accurate on pair with 85mm f1.8?
4,119 views & 0 likes for this thread
Latest registered member is dm19dm
1592 guests, 294 members online
