Thread started 11 Jun 2012 (Monday) 14:13
Which Lense For an Airshow?
cookiejay
Joined Jun 2012
Jun 11, 2012 14:13 |  #1
First off all - Hi, I'm a new member and fairly new to the photography world. I've been reading the forums for the last couple of hours now so thought I would sign up and say hello :p
I've read on here that without a doubt the best lens to use at an airshow is the 100-400...however, looks like everyone has the same idea as that one is out of stock on the weekend of the Royal International Air Tattoo! :(
So bearing that in mind, what lens would you guys take instead?
Thanks in advance,
Jay
amfoto1
Jun 11, 2012 14:17 |  #2
Hi and welcome to POTN Jay,
Sigma 120-400 OS or 150-500 OS should be good alternatives... They are also considerably cheaper than the Canon 100-400. They are the more traditional two-ring focus and zoom, too... while the Canon is push-pull type zoom (which some folks like, others don't).
Unless money is no object, then maybe a Sigma 120-300/2.8 OS with and without a 1.4X teleconverter. Might want a tripod... or at least a monopod... with that lens, though.
cookiejay
Joined Jun 2012
Jun 11, 2012 14:25 |  #3
wow that was quick! Thanks for the prompt reply and advice.
I'll have a look to see if those lenses are available.
Also, does anyone in the UK know of any good websites that you can rent lenses from?
I'm currently using http://www.lensesforhi​re.co.uk (external link)
Jay
stover98074
Jun 11, 2012 15:06 |  #4
Have you considered a MF lens? I use a Nikkor 300 f4.5 for air shows. The focus is set to infinity and it is a matter of framing the shot at an appropriate exposure. This is an example with the lens from a show last year.
I would also consider a Nikkor 500 reflex mirror lens. It is small, light weight, sharp. Both lenses are inexpensive and will work on an EOS body.
IMAGE: http://farm7.staticflickr.com/6149/6038923545_c3ac30a078.jpg
IMAGE LINK: http://www.flickr.com …s/stover98074/6​038923545/  (external link)
IMG_0513 (external link) by SWalker2009 (external link), on Flickr
Canon XSI, Asahi Pentax Auto Bellows, 50 Fujinon EP, 80 El Nikkor, 105 El Nikkor, 135 Fujinon EP
https://sites.google.c​om …xpensivemacroph​otography/ (external link)
DC ­ Fan
Jun 11, 2012 16:00 as a reply to  @ stover98074's post |  #5
Air show images from a Sigma 150-500m OS lens. (external link)
Focal Length: 500.0mm
Aperture: f/10.0
Exposure Time: 0.0016 s (1/640)
ISO equiv: 500
Exposure Bias: +0.67 EV
Metering Mode: Matrix
Exposure: program (Auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Focal Length: 150.0mm
Aperture: f/16.0
Exposure Time: 0.010 s (1/100)
ISO equiv: 100
Exposure Bias: none
Exposure: shutter priority (semi-auto)
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Camera Maker: Canon
Camera Model: Canon EOS REBEL T2i
Lens: 150-500mm
Image Date: 2011-05-13 14:38:45 (no TZ)
Focal Length: 403.0mm
Aperture: f/13.0
Exposure Time: 0.0050 s (1/200)
ISO equiv: 100
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
The Sigma is an effective lens, which is the least expensive 500mm stabilized lens. However, it's heavy, and those who are not used to large lenses may need some time to get used to its mass.
modchild
Joined Jul 2011
Jun 11, 2012 16:09 |  #6
I'm taking my Sigma pair of 120-400 OS for my 60D and my 150-500 OS for my 5D3 when I go to the Waddington airshow at the end of the month. I went there last year with a Tamron 28-300 VC which was long enough for most of the planes, but I borrowed a Canon 100-400 L from a guy there and the difference was amazing.
EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
watt100
Jun 11, 2012 16:33 |  #7
cookiejay wrote in post #14563989 (external link)
Thanks in advance,
Jay
I would bring the Canon 55-250IS - only 100
XSi (450D)
Canon 55-250IS
(cropped)
IMAGE: http://farm3.staticflickr.com/2602/4117657403_dce5c31013_b.jpg
altitude604
Jun 11, 2012 18:00 |  #8
Or you could try a 300 f/4L or the 400 f/5.6L as prime options too.
Erik - Three Miles Final (external link)
- Gear List -
cookiejay
Joined Jun 2012
Jun 12, 2012 02:30 |  #9
Thanks for that guys, will look in to which of these lenses I can get and how expensive they are.
Some great photos there, I've mainly done portraits up til now so really looking forward to the air show this year!
1Tanker
Jun 12, 2012 03:06 as a reply to  @ cookiejay's post |  #10
Try for a lens with IS if you can. Taking shots of "prop planes" at high-shutter speeds doesn't look nice, you want a low enough shutter speed to show some movement of the prop(with prop frozen, it looks like the plane is gonna fall out of the sky ;) ). For instance, a 400 non-IS would need a s/s of over 1/400 and 1/640 on crop to eliminate hand shake, but a s/s of 1/200 or under provides better prop action. 1/200 with a 400mm on crop would be very hard to keep still, but with IS, it's not a problem.
Therefore, if you were to consider the EF300/4L IS or EF400/5.6L, the 300 with a 1.4x TC would be the better choice in this situation.. for the IS, and possibility of having 300/4 and 420/5.6.. both with IS and AF.
Kel
Gear
BenMont
Joined May 2012
Jun 12, 2012 06:04 as a reply to  @ 1Tanker's post |  #11
Jay,
Who are you looking at hiring from? Lenses For Hire have some decent rates and a good reputation. Failing that Fixation and calumet Photo also hire the 100-400.
In the FRIAT enclosure, I have a photo from last year showing the majority of photographers all using the 100-400.
Ben
BenMontgomery.co.uk (external link) | Airliners.net (external link) | Flickr (external link) | My Photography Facebook Page (external link)
cookiejay
Joined Jun 2012
Jun 12, 2012 06:59 |  #12
BenMont wrote in post #14567176 (external link)
Jay,
Ben
Hi Ben,
I've been looking at hiring off lensesforhire as there the only ones I know of that don't charge a deposit... however they don't have any 100-400 available that weekend (most likely due to the airshow).
I'm a little stumped now as to what to get, as all the photo's taken at these events are using 100-400 :cry:
Off topic: I used to live just down the road from yourself in Nottingham, all my first photo's were taken at EMA down at each ends of the runway :D
kdrk888
Jun 12, 2012 07:23 |  #13
I like my 100-400mm, best all around lens for airshows. I used 70-200 before, too short on a full frame camera:
IMAGE: http://farm8.staticflickr.com/7095/7262718960_803c2c4172_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/douglasliu/7262​718960/  (external link)
6C3A0698 (external link) by Douglas Liu (external link), on Flickr
IMAGE: http://farm8.staticflickr.com/7226/7262725216_d6e114e4d6_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/douglasliu/7262​725216/  (external link)
6C3A0985 (external link) by Douglas Liu (external link), on Flickr
IMAGE: http://farm8.staticflickr.com/7084/7262728136_567ccd5578_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/douglasliu/7262​728136/  (external link)
6C3A1288 (external link) by Douglas Liu (external link), on Flickr
Douglas
Canon, Nikon, Sony. Too many gears, too little time.
cookiejay
Joined Jun 2012
Jun 12, 2012 07:26 |  #14
Wow love the pics! This is the quality of picture I was hoping to achieve.
How about a 28-300mm lens?
kdrk888
Jun 12, 2012 07:34 |  #15
cookiejay wrote in post #14567375 (external link)
Sorry, I don't have any experience with the 28-300. I used the 70-200 f4 L IS and the 70-200 f2.8 L IS II before I bought the 100-400. I guess the 28-300mm should be long enough on a cropped camera for most occasions. I don't know how fast it would focus though. Anyway, good luck with the show and come back to post some pictures here: https://photography-on-the.net/forum/showthre​ad.php?t=405758
Folks there are top notch and helpful.
Douglas
6,006 views & 0 likes for this thread, 16 members have posted to it.
1318 guests, 135 members online
