Thread started 14 Jun 2012 (Thursday) 01:14
5d mark 3 viewfinder light leak question
mantra
Jun 14, 2012 01:14 |  #1
Hi
i did test the wonderful 5d mark3 for 5 days
i guess it's the second generation , because it has not the lcd light leak issue
but i found a weird behavior
i took several shots in lightday , morning & afternoon , italy , landscape , blue sky , beautiful light
i had a 5d mark 3 (a friend's camera) and a 5d mark 2 (mine) ,i used a 17-40 F4L
well i did notice a weird exposure meter behavior
i used a tripod ,eye on the viewfinder and manual mode
as soon i did send away my eye from the viewfinder the exposure meter did start to give me a different meter
it did start to give a different light read moving my head around the viewfinder
i mounted on the tripod my 5d mark2 with same lens , and it was perfect
no light meter shift
i was used to put my thumb on the viewfinder to avoid light inside the viewfinder in some situation
does someone notice the same odd behavior of the exposure meter of the 5d mark3 ?
i'm talking about a normal situation with a sunny day
thanks a lot
cheers
sorry for my poor english
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Jun 14, 2012 01:25 |  #2
I believe that is "normal". Light goes through one end and out the other. And the metering sensor sits somewhere in between this path.
Julian
mantra
Jun 14, 2012 01:38 |  #3
jwcdds wrote in post #14576753 (external link)
thanks
but the 5d mark2 doesn't have this behavior
the 5d mark 2 exposure meter did not change
and i took some shots in normal condition , there is not bright light on the viewfinder
jwcdds
Best ofs: 8
Joined Aug 2004
Jun 14, 2012 02:06 |  #4
5D2 also doesn't have the new transmissive LCD viewfinder. Perhaps somethings had to be changed/tweaked to make it all happen. I don't think it's that big of a deal. It's unlikely the exposure is thrown off by all that much.
Julian
mantra
Jun 14, 2012 02:14 |  #5
jwcdds wrote in post #14576858 (external link)
thanks
the 5d mark3 should have the same 7d lcd transmissive
i will test it with 7d lcd
for me it's very tiresome , because meter different zone of the frame and i use a remote shutter , and i take several exposures !
did you notice the same behavior with the 7d ?
thanks
jwcdds
Best ofs: 8
Joined Aug 2004
Jun 14, 2012 02:28 |  #6
I haven't really paid attention to it, but then again, I rarely shoot with remote shutter.
If you're shooting remotely, can't you just put the VF cover on after you've gotten all your settings down? Or if you're relying on the camera's built-in meter... perhaps shoot in manual?
The light leak from the VF won't get past the mirror once it's up. It just might screw with your exposure if you're using anything other than M.
Julian
Gregg.Siam
Joined Jun 2010
Jun 14, 2012 05:43 |  #7
On page 86 of the 5D MKII manual it states you need to use an eyepiece cover as stray light will throw off the exposure.
It's normal for any SLR to have that effect.
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
mantra
Jun 15, 2012 04:49 as a reply to  @ Gregg.Siam's post |  #8
in short i'm the only one that found the viewfinder too much sensitive to the light compared to the other cameras
jwcdds
Best ofs: 8
Joined Aug 2004
Jun 15, 2012 10:04 |  #9
mantra wrote in post #14582104 (external link)
So far, sounds like you might be in the minority. But that might be simply the way you shoot and most people don't shoot the way you shoot. Your conditions put you in situations that allow the VF to alter your exposure metering more. Seems like while it rarely(never) affected you with the 5D2, it does now with the 5D3.
Julian
tagnal
Jun 15, 2012 19:42 |  #10
It's a common issue. That is why Canon DSLRs come with an eyepiece cover.
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
Toy List | flickr (external link) | FAA (external link)
2,570 views & 0 likes for this thread, 4 members have posted to it.
1053 guests, 103 members online
