Balliolman wrote:
Yes, the 1/40th rule in principle is a good one. Typically the rule is given as 1/30th. This means the stereobase, or the sideways shift of the camera between shots should be about 1/30th of the distance from the lens to the nearest object viewed in shot. Given your macro you will need to experiment: again a geared slidebar would likely aid you greatly. Keep posting: I enjoy viewing your work.
One major problem with the geared slidebar is , I don't use a tripod for outdoor macroshots- it's too clumsy for my style of shooting, but I do use one for inside set shots of flowers so can try using my macrostage for that, I can quite happily move that in 1mm increments, I'll just have to use the focus ring for focus stacking instead of the macrostage.
I've just installed stereophotomaker so hopefully no more vertical misalignments
- thanks for the hint on that.
Brian V.
