Thread started 14 Jun 2012 (Thursday) 21:26
(photo request) 10-22 EF-S on a 5DC/5D2
Stealther
Joined Jan 2012
Jun 14, 2012 21:26 |  #1
I've read you can simply remove the plastic EF-S baffle and mount a 10-22 on a full frame body as long as you stay above 12mm. Has anyone tried it? How does it perform compared to a 17-40? Please show us some samples!
Chris
Canon 5DMk2 | Canon 10-22 | Canon 17-40 4.0 | Canon 50 1.8 | Canon 70-200 2.8 II | Canon 600EX-RT | Manfrotto 055XPROB | Manfrotto 468MG | RRS B2LRII
My Feedback
Wilt
Jun 14, 2012 21:29 |  #2
POTN's Search is your friend...
https://photography-on-the.net …hp?p=14568835&p​ostcount=1
https://photography-on-the.net …p?p=14570427&po​stcount=11
https://photography-on-the.net …p?p=14429546&po​stcount=25
https://photography-on-the.net …p?p=13934509&po​stcount=15
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jun 14, 2012 21:35 |  #3
Wilt, that first link is for a 1DIIn, not a 1Ds.
500px (external link)
1x (external link)
instagram (external link)
Stealther
Joined Jan 2012
Jun 14, 2012 21:36 |  #4
Thanks Wilt, what did you use fir your search criteria? I tried "10-22 5d". Your search-Fu is stronger than mine!
I'm curious at comparable focal lengths how the 10-22 compares optically to the 17-40. I will have both a 60d and 5D2 and would love to use the 10-22 on both cameras if possible instead of buying a 17-40 that I would really only use on the 5d
Chris
My Feedback
rick_reno
Jun 14, 2012 21:39 |  #5
I've got a 5d and 7d and have the 10-22 and 17-40. IQ is very close between them, I can't detect an advantage of one over the other. 10-22 is wider and that is obvious.
Wilt
Jun 14, 2012 22:08 |  #6
Stealther wrote in post #14581146 (external link)
My search was on '10-22' and 'FF'
Using the 10-22 on both APS-C and FF is a bit like using a Canon lens on a Hasselblad...it was not intended to be so.
1Tanker
Jun 14, 2012 22:25 |  #7
Wilt wrote in post #14581255 (external link)
Nikon glass wasn't meant to be used on Canon either, but the results can be fabulous. :p
Rules are meant to be broken.
Kel
Gear
Wilt
Jun 14, 2012 22:55 |  #8
1Tanker wrote in post #14581313 (external link)
At least Nikon glass was designed to fill the 24x36mm frame properly! Unlike Canon EF glass trying to fill 42x55mm Hassy digital frame.
Well, if you want to full up your frame with the dregs of an image circle intended to only fill a 40% smaller frame, knock yourself out! False economy does lead to questionable decisions, I guess. :lol: Me, I'd rather get a suitable image circle.
Stealther
Joined Jan 2012
Jun 14, 2012 23:34 |  #9
If it works, it works. I haven't seen anyone say it looks horrible at comparable focal lengths against the 17-40. Wilt, I appreciate the help but can't help notice the barbs in your replys, is there a problem with looking for value? Or do you have personal experience with that setup and found it to be bad? My thinking is that I bought a UWA lens to shoot wide, if the lens works from 17-22, I lose out on the long side but I've spent exactly zero for it.
Chris
My Feedback
Wilt
Jun 14, 2012 23:46 |  #10
Stealther wrote in post #14581514 (external link)
I don't mind 'value'...which is why I own Tokina and Tamron lenses, not just Canon.
The problem I have is simply that APS-C is truly a different format from FF. So while no person in his/her right mind thinks of using 135 format lenses on Medium Format, we are stuck with folks trying to use APS-C lenses on FF dSLRs --equally absurd as Canon lenses on a Hasselblad -- simply because the lens mount is EF-S similar to EF, but nothing else makes their use suitable!
What do you think of folks trying to use their old Canon AE-1 TTL flash units mounted on the hotshoe of a Canon dSLR ETTL camera? Similarly absurd concept. My prior comment was an effort to bring levity to a laughable usage.
Stealther
Joined Jan 2012
Jun 14, 2012 23:53 |  #11
Wilt, I'm honestly not being argumentative, but all you have told me is that it's and EF-S lens, you shouldn't use it on a EF body and indirectly saying I'm being absurd for doing so. You haven't told me that the images that it will produce are drastically inferior image, only that you have a fundamental opposition for using something in a manner the manufacturer did not intend. Do you have anything to lend to my original question other than find new ways to indirectly insult?
Chris
My Feedback
Wilt
Jun 15, 2012 00:00 |  #12
Stealther wrote in post #14581553 (external link)
It does not fill the frame of the 24x36mm camera in the same manner in which a proper EF lens of the same FL would fill the frame. The EF-S lens image circle might 'just fill' the frame at the very edges of the image circle, while the EF lens of same FL would cover the frame sufficiently to allow the very edges (where IQ does fall off) to be discarded outside the 24x36mm frame area.
'Just getting by' is what you are doing, giving up things in an effort to save money. If you accept big compromises to save a buck, then buy the inferior filters for your lenses, too. Where do you draw the line...buying sub-$100 tripods?
Stealther
Joined Jan 2012
Jun 15, 2012 00:12 |  #13
Wilt, I understand what you're saying and it is OBVIOUSLY a stop-gap. Everyone is at different places in their lives and have different priorities, who are you to hold your standard over others? You seem like you have a lot to contribute in this area but your knowledge is overwhelmed by your sarcasm and complete lack of tact. Please don't bother with replying to my threads as it is clear that it is a waste of both or our time.
Chris
My Feedback
Wilt
Jun 15, 2012 00:46 |  #14
Stealther wrote in post #14581619 (external link)
I am sorry you viewed my comments as sarcasm! I meant only to raise the question of when do we cross the threshhold of compromising ourselves, in an effort at economy? ...the floppy sub $100 tripod, the flare causing filters, the electrical-contactless extension tube? There are tons of opportunities to achieve economy, but at what cost?
Does it not make you wonder why so few have ever posted example shots for what you ask, in spite of the fact that the lens has been around for 7-8 years or more?
Remember, I am the guy who gave those few links to examples per your request! Others may have expressed opinions, but not backed by examples.
<leaving thread>
saaFOTO
Joined Dec 2012
Dec 23, 2012 22:40 |  #15
hahaha do what you have to do! id say get a quality lens with out the risk of dinging a mirror or possible dust and dirt geting inside the 10-22
A CANON. A FEW LENSES. MIAMI.
3,220 views & 0 likes for this thread, 7 members have posted to it.
957 guests, 109 members online
