How do you calculate stops?
say I want to know how many stops from f/1.8 to f11
I thought that a stop was double or half. But it doesnt seem to be when talking f-stops
Excuse my ignorance on the subject. I just never got it.
AAphotog Senior Member 828 posts Likes: 3 Joined Apr 2012 More info | Jun 16, 2012 00:54 | #1 Permanent banHow do you calculate stops? 5d3, 50mm 1.4, 70-200mm F4 L, 17-40mm F4 L
Simpleboy Member 197 posts Joined Aug 2007 More info | Jun 16, 2012 01:10 | #2 For aperture is 1.4x, or more precisely the square root of 2.
RSMarco Goldmember 1,006 posts Joined Oct 2011 Location: Cheshire, UK More info | Jun 16, 2012 01:23 | #3 Or just count the clicks from whatever aperture your in..? _______________
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 16, 2012 02:06 | #4 RSMarco wrote in post #14586515 Or just count the clicks from whatever aperture your in..? Provided you know that by default the camera clicks off 1/3 stops, changeable in the menu to 1/2 stops. Elie / אלי
rrblint Listen! .... do you smell something? More info | 1.8 to 2=1/3 stop Mark
Jun 16, 2012 06:09 | #6 multiplying by 1.4 (or the square root of 2) will get you to the next whole stop.
Jun 16, 2012 06:35 | #7 Permanent banDamnn, this feels like highschool all over again 5d3, 50mm 1.4, 70-200mm F4 L, 17-40mm F4 L
JeffreyG "my bits and pieces are all hard" More info | Jun 16, 2012 07:02 | #8 OP is correct that a stop is a doubling or halving of the light. This is related to the area of the aperture. The only difficulty is that we report aperture as the ratio of the diameter to the focal length, and so the f/stop is a diameter term. Area is related to the square of the diameter. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Jun 16, 2012 07:23 | #9 Permanent banJeffreyG wrote in post #14587018 OP is correct that a stop is a doubling or halving of the light. This is related to the area of the aperture. The only difficulty is that we report aperture as the ratio of the diameter to the focal length, and so the f/stop is a diameter term. Area is related to the square of the diameter. In the field, the easiest way to think of whole stops is to start with two values, f/1.0 and f/1.4. Now look at two doubling sequences: f/1.0 - f/2.0 - f/4.0 - f/8.0 - f/16..... f/1.4 - f/2.8 - f/5.6 - f/11 - f/22..... These two sequences of doubling give all of the whole stops in one stop increments. Just read top line, bottom line, top line, bottom line as in f/1.0 - f/1.4 - f/2.0 - f/2.8 - f/4.0 - f/5.6 etc. I knew there had to be an easier way. Thanks! 5d3, 50mm 1.4, 70-200mm F4 L, 17-40mm F4 L
modchild Goldmember 1,469 posts Likes: 3 Joined Jul 2011 Location: Lincoln, Uk More info | Jun 16, 2012 08:43 | #10 There used to be a wristband going around with the f stops printed on it showing all in 1/3 stops from 1 to 32 but I just had a look on ebay and can't find it any more. Like the OP I'm getting terrible at remembering them. There used to be another band with all the shutter speeds in 1/3 stops as well, but I can't even find one of those either. Would be an easy way to remember though, if you could find one. EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
kf095 Out buying Wheaties More info | Jun 16, 2012 09:18 | #11 Agree with comment above, much easier to remember instead of calculating. M-E and ME blog
ScatterCr Senior Member 384 posts Likes: 4 Joined May 2010 Location: Pacific Northwest More info | Jun 16, 2012 10:38 | #12 |
| Latest registered member was a spammer, and banned as such! 2890 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
