Here is my sub-par attempt at using any type of lighting besides natural. I used two flood lights that we had lying around. Please give me advice on light placement and what I should do next time to improve.
IMG_6198-4
JoshuaaT Member 94 posts Joined Feb 2011 Location: Nevada More info | Jun 17, 2012 04:15 | #1 Here is my sub-par attempt at using any type of lighting besides natural. I used two flood lights that we had lying around. Please give me advice on light placement and what I should do next time to improve. IMG_6198-4 Canon T1i | Canon 50mm f/1.8 | Sigma 55-200mm f/4-5.6 | Sigma 18-50mm | 70-200mm f/4 L
stanclark Goldmember 1,143 posts Likes: 6 Joined Jan 2012 Location: Windsor,California More info | Jun 17, 2012 05:02 | #2 I have an issue with the cropping....why half a face.....Fine to use any kind of light just need place it differently .... a separation light behind the subject would have been nice...you can do nice portraits with one light and there is plenty of examples on this forum do a search... So if God made Man & Woman....whats his excuse for Nikon...
drvnbysound Goldmember 3,316 posts Likes: 12 Joined Aug 2009 More info | Jun 17, 2012 09:08 | #3 JoshuaaT wrote in post #14590180 Here is my sub-par attempt at using any type of lighting besides natural. I used two flood lights that we had lying around. Please give me advice on light placement and what I should do next time to improve. IMG_6198-4 Why do you say that its a sub-par attempt? What do you not like about the lighting? I use manual exposure settings on the copy machine
Jun 17, 2012 11:18 | #4 stanclark wrote in post #14590264 I have an issue with the cropping....why half a face.....Fine to use any kind of light just need place it differently .... a separation light behind the subject would have been nice...you can do nice portraits with one light and there is plenty of examples on this forum do a search... use the onr light partly one the subject and let some light spill over to background... look at this instead of the strobe use a flood and learn to bounce light around using reflector and foam poster board,,,,,,I saw a beautiful shot and they used kitchen foil on cardboard as a reflector... Thank you for those links. Letting light spill into the background would result in a non-black background which I wanted. I did not have a black backdrop, so I had to keep the lights off of it. drvnbysound wrote in post #14590698 Why do you say that its a sub-par attempt? What do you not like about the lighting? I did not like the harsh reflections on my skin from the light, but as you said, I had no control over the intensity of the lights. What would be the best way to even out the light? Canon T1i | Canon 50mm f/1.8 | Sigma 55-200mm f/4-5.6 | Sigma 18-50mm | 70-200mm f/4 L
stanclark Goldmember 1,143 posts Likes: 6 Joined Jan 2012 Location: Windsor,California More info | Jun 17, 2012 14:13 | #5 You used two flood lights one should be behind him and pointing at him the other light is out front lighting his face unless its a road side yellow stand ones....even with one light your only letting a little spill over....keeping the light highat an angle to his head.... So if God made Man & Woman....whats his excuse for Nikon...
drvnbysound Goldmember 3,316 posts Likes: 12 Joined Aug 2009 More info | Jun 17, 2012 14:18 | #6 JoshuaaT wrote in post #14591118 Thank you for those links. Letting light spill into the background would result in a non-black background which I wanted. I did not have a black backdrop, so I had to keep the lights off of it. I did not like the harsh reflections on my skin from the light, but as you said, I had no control over the intensity of the lights. What would be the best way to even out the light? I think there are a couple of things that you could do to alter both of the above comments... but they both also require space. Regarding the background that you wanted to keep black - move your subject (yourself) further away from the background. This will allow you to retain light, and even add more if desired, while keeping it off the background. Regarding the reflections on your skin - this goes back to intensity of the lights, other than moving the lights close or further away from yourself, you can also feather the light; for example, leave it in the same place, but point the light further in front of you, so that you are positioned in a section of the light that is not as intense as the center is. As with strobes and Speedlites, you can also get modifiers (such as an inexpensive shoot through umbrella) and set it up so that it's in front of your light as a diffuser, to also soften the light. I use manual exposure settings on the copy machine
Jun 18, 2012 00:19 | #7 Thank you everyone. I will try this again this week. Hopefully, I can improve some things based upon your guy's advice. What would be a better pose for this type of shot? Canon T1i | Canon 50mm f/1.8 | Sigma 55-200mm f/4-5.6 | Sigma 18-50mm | 70-200mm f/4 L
| Latest registered member is MWCarlsson 671 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
