Thread started 11 Dec 2005 (Sunday) 19:11
Sharpest EF/100mm-f2.8 vs EFS17-85mm
Davoxt
Dec 11, 2005 19:11 |  #1
I took these two photo's just to see if one lens is sharper then the other, both where cropped at 100%.
Both taken around 5m from the sprinkler, with the photo no 1 being the 100mm.
Gone to Dark Side
Nikon D600, 16-28mm f2.8 Tokina, 24-70mm f2.8 VC Tamron, 70-200mm f2.8 VRll Nikon.
tim
Light Bringer
Dec 11, 2005 19:17 |  #2
I would expect the prime to be sharper, especially because macro lenses are always dead sharp - I have the 100mm. Unless you're looking at a close crop you should have a hard time telling them apart.
gasrocks
Dec 11, 2005 23:55 as a reply to  @ tim's post |  #3
Ok, but...... not much of a pix to judge by. How about something else?
Davoxt
Dec 12, 2005 01:31 |  #4
Two more taken 350m from building then cropped again at 100%, 100mm first.
Taken at midday so afair bit of heat haze around.
Gone to Dark Side
xmetal2001
Joined Jun 2005
Dec 12, 2005 01:41 as a reply to  @ Davoxt's post |  #5
Looks like in the 2nd pic of the ones you just posted the building is out of focus. The focus seems to be on the branches in the lower left.
pault107
Joined Nov 2005
Dec 12, 2005 03:45 |  #6
Hmm, strange thread :D
nitsch
Dec 12, 2005 04:31 |  #7
The sprinkler shot is hard to judge because a) the lenses are different focal lengths you should have moved so the subject remained the same size in each shot and b) you have miss focused the second shot, if you look at the grass it looks like it is focused behind the sprinkler. The second set of shots suffer from the same problems. The test is fairly pointless, the 100mm f2.8 is one of the sharpest primes on the market and you are comparing it to a consumer level zoom, get out there and take some creative shots! I bet you've got some cracking scenery/wildlife out there. :-)
tim
Light Bringer
Dec 12, 2005 04:39 as a reply to  @ xmetal2001's post |  #8
Good call. The pictures are meaningless because of that.
Jakpro
Dec 12, 2005 07:35 |  #9
I think that the second set of photos brings up a good point on the problems assocaited with auto focus.
If you are not paying attentioon to the focus points, something small in thew foreground can really "trick" the auto focus. If you were manually focusing, this would probably not be a problem.
nitsch
Dec 12, 2005 07:42 as a reply to  @ Jakpro's post |  #10
Or just using the centre point for AF would get around this too.
nitsch
Dec 12, 2005 07:49 as a reply to  @ nitsch's post |  #11
Further to this post, another thing you may want to do for future lens comparisons is keep the aperture the same on both lenses for the shots you are comparing.
cc10d
Joined Jan 2004
Dec 12, 2005 10:14 |  #12
RIGHT !
cc
2,970 views & 0 likes for this thread, 8 members have posted to it.
2264 guests, 138 members online
