I like so many edit a lot of photos this way, but is there a way to pre set the "ENABLE PROFILE CORRECTIONS" so i dont have to keep ticking it to change it, i know its maybe petty but any way of doing this?
Thanks in advance
Derek
Jun 18, 2012 18:09 | #1 I like so many edit a lot of photos this way, but is there a way to pre set the "ENABLE PROFILE CORRECTIONS" so i dont have to keep ticking it to change it, i know its maybe petty but any way of doing this?
imjason Goldmember 1,667 posts Likes: 3 Joined Nov 2010 Location: Bay Area, CA More info | Jun 18, 2012 18:43 | #2 dexy101 wrote in post #14597666 I like so many edit a lot of photos this way, but is there a way to pre set the "ENABLE PROFILE CORRECTIONS" so i dont have to keep ticking it to change it, i know its maybe petty but any way of doing this? Thanks in advance Derek yes! Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Jun 18, 2012 19:19 | #3 Ah, what a wonderful reply, thanks so much Jason
tonylong ...winded More info | Jun 18, 2012 20:03 | #4 I'll just add that in the Develop module the normal button is Reset. If you press the Alt/Opt key it changes to the Set Default button. Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 19, 2012 03:08 | #5 Select all the images that you want to apply the preset to them. The Previous button at the bottom right changes to Sync. At the side of the button there is a little toggle switch that makes it Auto-Sync. Click on the preset, it will be applied to all the selected photos. Remember to change the button back to Sync or to deselect the images. Elie / אלי
Calicajun Goldmember More info | Thanks big help to me too. Remember, Stressed spelled backward is Desserts.
| Latest registered member is semonsters 1467 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
