Anyone try this? Will it focus?
Jun 18, 2012 22:10 | #1 Anyone try this? Will it focus? Steve Cavanaugh
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jun 18, 2012 22:12 | #2 I haven't tried it but it should not work. None of the MkIII AF points are better than f/5.6 Not sure why, but call me JJ.
thephotographynut Member 128 posts Joined May 2012 More info | Jun 18, 2012 22:26 | #3 benttop wrote in post #14598773 Anyone try this? Will it focus? I assume you want to use it at 400mm. No it won't work. You need a 1D and even then it will only work with the center AF point.
Interesting. The manual on the extender seems to imply that it should work, but I know it didn't work with my 5DM2. Am I misreading this? http://gdlp01.c-wss.com …xtender-ef-14x-iii-en.pdf Steve Cavanaugh
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | That PDF doesn't mention which combo's will AF and which won't. It just has the exceptions on MFA for some lenses. Kel
monty28428 Cream of the Crop More info | Jun 18, 2012 23:21 | #6 Yeah - it will mount -- but that does not mean it will autofocus....
<sigh>... it's a pity. Steve Cavanaugh
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jun 18, 2012 23:36 | #8 On some lenses AF will be retained. If the final aperture is f/5.6 or less, you have AF. On the 100-400 at 400, you are already at f/5.6 so adding the t-con pushes you over the limit. Not sure why, but call me JJ.
monty28428 Cream of the Crop More info | Jun 18, 2012 23:50 | #9 ^+1
Jun 19, 2012 03:13 | #10 Taped pins used to work on the 5D, but it had clumsy AF points. I tried this on the 7D and I had no joy at all. http://natureimmortal.blogspot.com
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jun 19, 2012 03:17 | #11 Taping the pins is a very simple operation that does no damage. Why not try it? It allows me to use my 100-400 and 1.4x on a 5D2. Richard
ydelta Junior Member 23 posts Joined May 2012 Location: London, UK More info | Generally speaking extenders should be avoided with zoom lenses other than f/2.8. Not only the AF may not work but the IQ won't be what you expect. 60D + Grip BG-E9 - Canon 50mm f/1.4 - Canon 24-105mm f/4 L IS - Canon 70-200mm f/2.8 L IS II - Canon 400mm f/2.8 L - Canon Ext 2x II
bob_r Goldmember More info | Jun 19, 2012 08:49 | #13 ydelta wrote in post #14600184 Generally speaking extenders should be avoided with zoom lenses other than f/2.8. Not only the AF may not work but the IQ won't be what you expect. I have often used extenders with a 100-400 and don't find the IQ to be so bad that the images are unacceptable. I have to manually focus, but had to do that with film cameras for many years. Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
thephotographynut Member 128 posts Joined May 2012 More info | Only problem with taping the pins is you get the glue from the tape all over the pins. There is also a slight risk that the tape / adhesive could make its way down into the camera.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jun 19, 2012 10:59 | #15 thephotographynut wrote in post #14600529 Only problem with taping the pins is you get the glue from the tape all over the pins. There is also a slight risk that the tape / adhesive could make its way down into the camera. I've used a taped Kenko 1.4x converter for several years now and I don't recognise what you say. Plain, boring old sellotape is what I used and its been fine. Richard
| Latest registered member is semonsters 1471 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
