Just set up my new Einsteins, two light set up with one soft silver umbrella, one octobox, and my 580exII set up as back light. Using the cybersystem. Wife not crazy about sitting for an hour, but she did. CC welcome as I'm new to this.
thanks Jeff
pyro1 Goldmember More info | Jun 19, 2012 05:49 | #1 Just set up my new Einsteins, two light set up with one soft silver umbrella, one octobox, and my 580exII set up as back light. Using the cybersystem. Wife not crazy about sitting for an hour, but she did. CC welcome as I'm new to this. 1DX MKIII, Twin 1DX, 5D mk III - EF 16-35 f/2.8L II USM - EF 24-105 f/4L IS USM - EF 70-200 f/2.8 L IS USM II - EF 100-400 f/4.5 L IS USM - EF 100 f/2.8 L Macro IS USM - EF 85mm f/1.2 L II USM - Tam 24-70 f/2.8 Di VC - 580EXII - Einsteins & CyberSync System - Vagabond Mini -
oldvultureface Goldmember More info | Jun 19, 2012 06:43 | #2 Looks underexposed to me. Also, the lighting on the face looks flat. Maybe increase the ratio between the two main lights for more definition.
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Jun 19, 2012 08:58 | #3 Do this. Forget all the 580ex and what not. Start with one light and pick your choice of modifier. Now use light meter or chimp to get the proper exposure. Then add 2nd light. Fuji XT-1, 18-55mm
john5189 Senior Member 598 posts Likes: 6 Joined Dec 2008 More info | Jun 19, 2012 09:13 | #4 Is your monitor too bright because your image is dark. Wedding Photography in Herefordshire.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jun 19, 2012 10:22 | #5 Looking at the catchlights in the eyes, it appears that the dimmer light source was farther from the camera while the brighter light source was closer to the camera...and THAT results in the frontal lighting which fails to 'model' the facial features. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ob_srt4 Member 191 posts Likes: 5 Joined Jan 2012 Location: ontario, canada More info | Jun 19, 2012 10:34 | #6 very dark Ryan - Pausedmemories Photography
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jun 19, 2012 11:02 | #7 Ignore the presence of the the flash tube in your Einsteins. Turn on ONE light, modelling light only. Move it around your wife
...and note how her facial illumination can be made to be more pleasing or less pleasing (few folks are identical in how the right side of the face pleases vs. the left side of the face pleases! Don't bother to take any photos, merely learn to SEE what the lighting position does to flatter and not flatter your wife. Most photographers fail to first understand how photographic lighting can FLATTER the subject; your goal is lighting to 'flatter', not merely 'illuminate'. If more photographers had photographic flattery of the subject as a goal, they would not automatically buy only speedlights for portraiture, because the would understand that speedlight positioning is merely guesswork for most photographers. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
davisphotos Member 190 posts Joined Aug 2010 Location: Portsmouth, NH More info | Jun 19, 2012 13:21 | #8 There are two competing catch lights in here eyes, one of which is completely obscuring her pupil. I agree with what the others have said-start with one light, probably the octabox, and move it around to find the most flattering light. The size of the catchlights indicates your lights were not very close to your wife. Moving the octabox closer will result in softer, more flattering light. Maine Wedding Photographer Andrew Davis
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jun 19, 2012 13:57 | #9 My suggestion to those who are trying to learn lighting is to first start with a single HARD light source. The use of modifier like softboxes is meant to reduce shadow definition. But when you are learning lighting it is important to learn the affects of precise placement, and hard sources permit you to better see the effect via the placement of shadows. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Thanks for all the comments. I will work on everything and give it a go. Thanks again for all the information, I'm just starting out with the lights. 1DX MKIII, Twin 1DX, 5D mk III - EF 16-35 f/2.8L II USM - EF 24-105 f/4L IS USM - EF 70-200 f/2.8 L IS USM II - EF 100-400 f/4.5 L IS USM - EF 100 f/2.8 L Macro IS USM - EF 85mm f/1.2 L II USM - Tam 24-70 f/2.8 Di VC - 580EXII - Einsteins & CyberSync System - Vagabond Mini -
This one is from the same sitting. Lighting I think is a little better. Is it still too dark? 1DX MKIII, Twin 1DX, 5D mk III - EF 16-35 f/2.8L II USM - EF 24-105 f/4L IS USM - EF 70-200 f/2.8 L IS USM II - EF 100-400 f/4.5 L IS USM - EF 100 f/2.8 L Macro IS USM - EF 85mm f/1.2 L II USM - Tam 24-70 f/2.8 Di VC - 580EXII - Einsteins & CyberSync System - Vagabond Mini -
s2kennyc Senior Member 849 posts Likes: 249 Joined Aug 2009 Location: Southern CA More info | Jun 20, 2012 02:57 | #12 Yes, it's still too dark. Do you have a light meter to measure the light? It takes the guessing game away. -Ken
Jun 20, 2012 06:11 | #13 s2kennyc wrote in post #14604640 Yes, it's still too dark. Do you have a light meter to measure the light? It takes the guessing game away. Yes, the cyber commander, I think it's me in my PP. I'll work on it. 1DX MKIII, Twin 1DX, 5D mk III - EF 16-35 f/2.8L II USM - EF 24-105 f/4L IS USM - EF 70-200 f/2.8 L IS USM II - EF 100-400 f/4.5 L IS USM - EF 100 f/2.8 L Macro IS USM - EF 85mm f/1.2 L II USM - Tam 24-70 f/2.8 Di VC - 580EXII - Einsteins & CyberSync System - Vagabond Mini -
dmward Cream of the Crop More info | Jun 20, 2012 09:26 | #14 If you have CC, its a simple matter to get the Einsteins set for head shots (portraits). Image hosted by forum (601816) © dmward [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. David | Sharing my Insights, Knowledge & Experience
| Latest registered member is semonsters 1592 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
