Hi All,
I love this forum, people always wanting to help especially learners like me. I have a 50mm f1.8 and also a 17-50 f2.8 VC. I was playing up shots in a park yesterdat, well with a model
and here are the things i noticed.
- I tried to move away from auto focus and instead focus using manual, I zoomed in when using the tamron and then manual focused and then zoomed out to take the shots, whilst some of the shots were sharp, others were not. Could this be that I was shaking (not using tripod) and in some cases, my focus point had actually moved. I always try and focus on the eyes.
- It was in a park with a pond in the background, so I decided to use a narrow DOF but not blur it out too much, so around f2.8 and f4 ISO 200. what are the general guidelines on ISO settings outdoors where there is enough ambient light ?
- Sometimes when I took a shot with the pond at the background, it became overexposed and instead of seeing clear water, it became kind of white.
- Lastly, I would like to know what kind of touchups one can do to potraits, I know how to use the healing brush and the spot healing brush, also learnt how to use the Gausian blur to pop out a picture. I would like to learn the obvious thing, I always like when the skin is a little blurred, it gives a softer finish as long as its not overdone. Is there anything in particular I ought to be looking at ? When I also loaded the raw file, and attempted to correct the white balance using the while balance tool, the result was awful. I was better off leaving it the way it was before, being that the picture was taken outdoors, and I used a white card (took a picture of a white piece of paper, and used it as custom white balance). I have been hearing of grey card, not sure what I should be doing ?
Thanks in advance.
