Dooku wrote in post #14602993
was thinking of a canon 17-55, but after checking this lens out in a camera shop I did not buy it.
Somehow I expected more field of view
even though it's an EF-S lens.
The 24-105 is about the same as a 37mm(low end) on the 50D. This sounds like you are multiplying some lenses by the crop factor, but not others ?
The focal length does not change regardless of mount (EF or EF-S) or what camera it is attached to. So your 24mm does not become 37mm in the example above.
You say you expected more field of view? Well, there isn't a massive gap between the 24mm you already have and the 17mm you were looking to get. There is enough to make a significant difference, but not massively different.
The 10-22 is your better option (imo), I have both that lens and the 24-105L and frequently carry them at the same time on two bodies, switching between them as my focal length needs change. They complement each other very well, with no overlap and only a tiny gap between them, which you won't miss.
The 17-55 though has a big overlap with the 24-105, you will only add the 17-24mm range to your arsenal, with the majority of that focal length range (24-55mm) being duplicated.
