Thread started 20 Jun 2012 (Wednesday) 00:05
7 D Noise
J ­ R ­ Mohan
Gallery: 218 photos
Jun 20, 2012 00:05 |  #1
I want to upgrade to 7 D body but hear a lot that it gives noise beyond ISO 400 . What is the correct finding.
I will be using 70-300 L lens with it if upgraded.
Thanks.
Jai.
jaomul
Joined Apr 2011
Jun 20, 2012 02:35 |  #2
Hard to say what your expectations are here. One of my favourite shots is at ISO 6400 printed at 8x10 inches with minimal pp. I upgraded from a 50d and found the 7d a nice bit better. Check the 7d pictures form and you will see many pictures @ ISO 400 and up.
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
kMatt
Joined Mar 2012
Jun 20, 2012 02:40 |  #3
Out of curiosity, what body do you own currently? Even the most basic of beginner bodies don't show noticeable noise at ISO 400, so it's weird to think a high end DSLR such as the 7D would.
Of course even the highest level bodies (1Dx, 5D3) show noise at higher levels, but how high are YOU planning to use?
talbot_sunbeam
Jun 20, 2012 03:53 |  #4
You've already tried searching the forum on this, yes?
Because it's been done to death already...
7D, 450D | 17-55, 10-22, 55-250, 50 1.8, 580EXII | YN568II | YN622 x3 | Magic Lantern | (Still) Jonesing for a 70-200 2.8...
Turns out a gripped 7D + 622 + 580exII + 70-200 2.8 IS MK2 is BLOODY HEAVY! Who knew?!!
J ­ R ­ Mohan
Gallery: 218 photos
Jun 20, 2012 03:54 |  #5
kMatt wrote in post #14604618 (external link)
Presently I am using 50 D. At the higher end ISO usage should be from 1000 to 1600.
Jai.
KCY
Unlocked the hidden 117 point AF
Jun 20, 2012 04:17 |  #6
Here is an ISO test I did years ago, you can view the original uploads, however I did reduce the size of these (bandwidth issue back then).
It might help give you an indication of what is acceptable to you
http://kcyeung.smugmug​.com …hings/7D-Extreme-ISO-Test (external link)
KC - The Circle of PoTN - Member of the UCPC
My Gear|My Smugmug (external link)|Pong
pknight
Gallery: 39 photos
Joined Feb 2006
Jun 20, 2012 06:44 as a reply to  @ KCY's post |  #7
If you plan to pixel peep exclusively, and are only concerned about what your images look like at 1:1 resolution on your monitor, then there might be concern at the higest ISO settings on the 7D. If you are going to print images or view them at normal resolutions on screens, don't worry about this issue.:)
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
crumbleton
Joined Apr 2012
Jun 20, 2012 06:48 |  #8
Unless you're actually taking pictures it's silent. The shutter noise is louder than my 450d but not annoyingly so...
Oh I see what you mean :-)
I upgraded from a 450d and was a bit worried about noise but that's usually only a real problem on ISOs higher than I was used to. Depends on the situation and ambient light plus the noise that is there for some reason responds really well to LR denoise.
http://www.flickr.com/​photos/ao_d/ (external link)
Buylongterm
Jun 20, 2012 07:08 |  #9
400? Nah. However for me, 1600 was pushing it.
Christian
@WerthLiving (Follow me on Instagram)
Canon EOS 5D MK III Gripped | 35mm f/1.4L | 70-200mm f/2.8L IS MK II |100mm f/2.8L Macro | 24mm-105mm f/4.0L |
jase1125
Jun 20, 2012 07:12 |  #10
You will be fine. Go buy the 7D.
Jason
Scott ­ M
Gallery: 111 photos
Jun 20, 2012 07:22 |  #11
I've gotten acceptable results (for me) as high as ISO 6400 on the 7D. However, I am not a pixel peeper.
Photo Gallery (external link)
Buylongterm
Jun 20, 2012 07:28 |  #12
Scott M wrote in post #14605124 (external link)
Nor am I. In fact,I'm not even sure what pixel peeping means. Lol.
Christian
KCY
Jun 20, 2012 07:36 |  #13
Buylongterm wrote in post #14605142 (external link)
Here you go, look at this 4000000% enlargment, look at that glorious pixel ;):p
gjl711
Jun 20, 2012 07:41 |  #14
KCY wrote in post #14604740 (external link)
That ISO 204800 is totally unusable. What a piece of junk. ;)
To the OP, at ISO 1600 and even 3200 you should have no issues assuming that you get the exposure correct. Even the 40D did fine to ISO 3200 properly exposed. At 6400 you'll start seeing noise and will have to use some noise reduction in post if you're shooting raw.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
davidc502
Jun 20, 2012 07:57 |  #15
Here is one example of pixel peeping when it comes to "Lenses". There are all sorts of types, but usually it's the 400% crops that can kinda get to people.
http://www.ukphotosafa​ri.org …t-friends-pixel-peep.html (external link)
_
My Gear is ---> Here
2,535 views & 0 likes for this thread, 12 members have posted to it.
7 D Noise
2935 guests, 139 members online
