Thread started 20 Jun 2012 (Wednesday) 03:48
Opinion requested re micro adj required or not
2slo
Gallery: 1113 photos
Joined Oct 2011
Jun 20, 2012 03:48 |  #1
Hi,
could I ask those with experience of microadjusting lenses to take a look at the shot below please and tell me whether you think my lens needs MA. I think it does but, first of all I've never done this before and secondly I've no benchmark to compare it with, hence I'd like opinion please, preferably from those who've done this procedure.
The shot is a JPEG, taken with a 1DmkIV plus 400mm f/5.6 lens. Taken from 20m away (50 x the focal length) 1/400 sec; ISO 200. The camera was tripod mounted and wired remote activated. AF using liveview at max mag was used. 3 shots were taken, all look the same. The only pp was minor sharpening. What you see is a 100% crop.
If you look at the yellow security info on the box, to me that's OOF hence I think the lens needs MA. That's just my opinion of course, would you agree or am I expecting too much?
Thanks for looking.
hollis_f
Jun 20, 2012 05:15 |  #2
2slo wrote in post #14604699 (external link)
You were in liveview and used AF. Did you use Live Mode or Quick Mode for the AF (see p.138 of the manual)? The former doesn't use the normal AF system, so MA would have no effect!
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
2slo
Joined Oct 2011
Jun 20, 2012 05:34 |  #3
hollis_f wrote in post #14604841 (external link)
err, p 138 of the 1DIV manual I have covers manual focussing?
I enabled live view stills from the menu, camera in manual mode/jpeg/ settings as above and AFd at full mag then 100% crop of the resulting image. Any help?
EDIT: p136 covers quick mode in my manual. No, I didn't use that, just as detailed above. I used back button AF in conjunction with wired remote.
hollis_f
Jun 20, 2012 06:01 |  #4
2slo wrote in post #14604873 (external link)
Whoops! Dunno why I assumed it was a 7D. Silly me!
OK. There are two ways your 1D can focus in liveview (maybe three if it has face-recognition, but we'll ignore that). Live Mode is the default. That takes the data from the sensor and looks at the contrast, then it moves the lens a bit, checks the contrast again, moves the lens, checks, and round and round until there's no improvement in the contrast.
This method is slow, but accurate - because it is using the image produced by the sensor.
The other methos, Quick Mode, uses the AF system that is used most of the time (all of the time when not in liveview). In this mode some of the light is directed to a special AF sensor. This uses a complicated mechanism called Phase Detection which can tell just how far the lens has to move and in which direction to get spot-on focus. So it makes that measurement, tells the lens how far to move, waits for the lens to say 'OK, I'm there' and then tells the camera it's ready to go.
This method is very fast but it does rely on the camera being able to judge how far the lens must move and also on the lens moving the same distance as it's been told to move.
It's impossible to engineer such systems to be 100% accurate, so there is some leeway in how accurate the two systems are. Most of the time there's no real problem, but you can get some cases where a camera that's slightly front-focusing matches with a lens that's slightly front-focusing to get a system that's noticeably front focusing. That's where Micro Focus Adjust can help.
You can check your lenses using the different focusing modes in liveview. Take a couple of images using Live Mode (using contrast detection, which doesn't use the AF sensor) and a couple using Quick Mode (which does use the AF sensor). If the latter are not as sharp as the former then you may have a problem.
2slo
Joined Oct 2011
Jun 20, 2012 06:18 as a reply to  @ hollis_f's post |  #5
Thanks Frank, I will give that a try as soon as I get a chance.
Just based on the image above from the way I did it, do you think that's accepatably sharp for a 100% crop from 20m? Having read a bit on MA, the tethered method of MA using the EOS utility, set up with camera as described above seems worth a try. Easy to reset to default if it doesn't produce an improvement.
huntersdad
Jun 20, 2012 07:36 |  #6
No, not acceptable and yes, you need to try MA'ing that lens. I'll give you an easier way to do it though - tape a $1 dollar bill to a flat wall, take camera and lens and setup roughly 20 ft. from the wall. Using LV, focus on the center of the bill. Now using LV again, move the focus point to the lower left corner of the bill where you should see some printed lines in the material. They should be absolutely sharp. If not, time to start adjusting until they are.
This is the method I use and never have to take a picture to do it and it has never let me down.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
2slo
Joined Oct 2011
Jun 20, 2012 08:22 |  #7
huntersdad wrote in post #14605159 (external link)
Thanks for the reply and info, what you suggest is pretty much the same basic principle as the tethered method albiet simpler and easier to do.
I would say that 20ft sounds a bit too close for a 400mm lens though, most suggest 25 - 50x the focal length to adjust at distances appropriate to those the lens will be used at.
gjl711
Jun 20, 2012 08:30 |  #8
Just a guess, but did the lens have a filter? From the image it looks more as if there are optical reflections. I have had issues with filters in the past and they sure look like the photo you posted.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
joedlh
Gallery: 52 photos
Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea.
Jun 20, 2012 08:39 |  #9
You might try doing this with a better subject. It looks like it was shot through glass and there was out of focus stuff in the foreground partially obscuring it. Not a good candidate for focus testing. You need a clean light path.
Joe
Gear: Kodak Instamatic, Polaroid Swinger. Oh you meant gear now. :rolleyes:
http://photo.joedlh.ne​t (external link)
Editing ok
LeeRatters
Jun 20, 2012 08:40 as a reply to  @ gjl711's post |  #10
I done my 85mm & possibly the 50mm in camera!!
I used normal back button focus then flicked to live view, zoomed in & compared it by manually adjusting the focus of the lens. Depending which way brings the live view image into better focus, adjust the MA then try again.
Obviously tripod mounted, all in line etc
>> Flickr << (external link)
>> Instagram<< (external link)
jhayesvw
Gallery: 167 photos
Jun 20, 2012 08:50 as a reply to  @ LeeRatters's post |  #11
for a subject 60+ ft away and a 100% crop it looks good to me.
but I would use teamspeed's focus chart in his sig to check for issues
My Flickr (external link)
sambarino
Jun 20, 2012 08:50 |  #12
gjl711 wrote in post #14605330 (external link)
Ditto. I got shots that looked like this with my 100-400L until I took the filter off. The lens performs much better without a filter and with a hood than it does the other way around.
2slo
Joined Oct 2011
Jun 20, 2012 08:56 as a reply to  @ sambarino's post |  #13
Thanks Gents. No filter fitted. I'm currently trying a test chart on a wall at 20m. The results just look blurry whichever way I MA (tried in +/- 5 steps up to +/- 20). I'm going to try it at half the distance and see what smaller changes look like.
hollis_f
Jun 20, 2012 09:05 |  #14
2slo wrote in post #14605435 (external link)
You might want to invest in FoCal (external link), a bit of software that automates the MA process.
2slo
Joined Oct 2011
Jun 20, 2012 09:15 as a reply to  @ hollis_f's post |  #15
You must have been standing over my shoulder this morning Frank, just what I've been looking at :)
Having said that, doing adjustments at 10m using a test chart, I can see a definite improvement with a MA of +5 (on the camera screen anyway) so I'm setting it on that for now, more test pics to follow, if this is boring let me know and I'll cease immediately :)
3,758 views & 0 likes for this thread, 11 members have posted to it.
2886 guests, 139 members online
