Thread started 21 Jun 2012 (Thursday) 16:54
7D and Lightroom 4 settings starting point question?
Box ­ Brownie
Jun 21, 2012 16:54 |  #1
Hi All
I recently got the 7D and have a learning curve to handle the RAWs compared the old 40D.
Now with the 40D the Capture Sharpening defaults seemed fine and the Noise equally so but the 7D is a different kettle of fish
IMAGE: http://www.luminous-landscape.com/forum/Smileys/default/cheesy.gif
So to anyone using the 7D what starting point for Sharpening settings and Luminance Noise have you found works satisfactorily? I say starting because I am sure that I wil have to adjust them subject to whether said image is say bird feathers (high frequency) or architecture (low frequency)
IMAGE: http://www.luminous-landscape.com/forum/Smileys/default/huh.gif
Many thanks in advance for some pointers.
Oh, on the fairly simple walkabout first set of images I found to get ETTR I was using at least +2/3 EC compared to the 40D where +1/3 was my usual setting using Centre Weighted metering.
IMAGE: http://www.luminous-landscape.com/forum/Smileys/default/smiley.gif
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
Box ­ Brownie
Jun 22, 2012 07:17 |  #2
bump ???
I know only a day gone by but thought surely there were other 7D users using LR4 who would have covered this aspect and could share :D
bkcorwin
Jun 22, 2012 07:52 |  #3
Here is a bump for you because i am curious as well. I found some threads a long time ago that dealt with this a little bit but cant seem to dig them up.
For what its worth I have a 7d and right now my sharpening default amount is set to 45.
DDL
Jun 22, 2012 08:00 |  #4
This is where I start.
http://www.phototestce​nter.com …non_7d__raw_set​tings.html (external link)
DDL
GearList
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jun 22, 2012 08:04 |  #5
I have my sharpening set to 55 typically. NR I set manually and will never never ever go above 30 for NR and thats pushing it alot. Even with my 60D and ISO 6400 I leave it around 25-30 and ISO 1600 I'm usually around 15.
I just hate the detail that gets washed out with the NR and once you resize your image most of it goes away anyway.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
tzalman
Fatal attraction.
Jun 22, 2012 08:34 |  #6
Kinda hard to relate seriously to someone who makes recommendations for LR sharpening and ignores two out of the four sliders. Or are they supposed to be zeroed, which will mean losing the two features that makes LR sharpening special, deconvolution (Smart) / USM blending and edge masking.
Elie / אלי
DDL
Jun 22, 2012 08:47 |  #7
tzalman wrote in post #14615680 (external link)
He mentions those settings in the text above the table; not sure what they should be for LR4.
DDL
GearList
talbot_sunbeam
Jun 22, 2012 09:01 |  #8
Can't remember the exact numbers offhand, but I basically used to use the defaults on my old 450D in terms of capture sharpening (maybe 25-ish?), but with the 7D I push up the capture sharpening to maybe 50-ish, and apply that preset on ingest automatically.
I also have a bunch of NR presets for different ISO that I eyeballed.
7D, 450D | 17-55, 10-22, 55-250, 50 1.8, 580EXII | YN568II | YN622 x3 | Magic Lantern | (Still) Jonesing for a 70-200 2.8...
Turns out a gripped 7D + 622 + 580exII + 70-200 2.8 IS MK2 is BLOODY HEAVY! Who knew?!!
tzalman
Fatal attraction.
Jun 22, 2012 18:13 |  #9
Noise Reduction (NR) is turned off by default so you must make adjustments manually. Although the settings in the table are the ones that matter most, try raising both the luminance and colour Detail settings to 70 or 80 for even more fine detail at the expense of a tiny bit more noise.
The reference is to the Detail sliders in NR, not Sharpening.
Elie / אלי
Zivnuska
Gallery: 72 photos
Jun 22, 2012 19:00 as a reply to  @ tzalman's post |  #10
Sharpening
http://www.youtube.com​/watch?v=KXtTeixz92A (external link)
www.zivnuska.zenfolio.​com/blog (external link) = My Blog
www.zivnuska.zenfolio.​com (external link)
"It's not tight until you see the color of the irides."
Box ­ Brownie
Jun 22, 2012 19:34 |  #11
Hi guys
Many thanks for insight, feedback and links/pointers. All will aid my understanding to get the best out of my 7D RAWs :D
6,427 views & 0 likes for this thread, 7 members have posted to it.
914 guests, 117 members online
